additional lock (2 Viewers)
Oct 2, 2011
864
571
Scotland
Since 2011
I'm thinking about fitting an additional lock on the habitation door. As I have said before on previous threads the bottom of the door sticks out a little bit and I have noticed a bit of wind noise from it. It does sit better with the new bottom hinge though. I am thinking about a lock that is a key from the outside and a turn lever on the inside. I would be looking for this to hold the door in tight so it fills the frame like it is meant to. I think it is a better option than just messing about until the door is a better fit as it also improves security. Looking for suggestions as to the lock to use, preferably easy to fit, and whether or not I am doing something that is not really wise.
Gordon
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If you are thinking of fitting an internal lock either in the door frame or habitation door, I would leave well alone, it is not a job for D.I.Y.
Peter
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i used to work on the thief's thought of if it has more than standard locks there is something inside worth the effort of breaking in for.
therefore i never put additional locks on any of my work vans (when i had them before).
maybe if its just the bottom of the hab door i would try and use something that can only be opened from the inside but fit one at the top too.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
maybe if its just the bottom of the hab door i would try and use something that can only be opened from the inside[HI] but fit one at the top too.[/HI]
Agree with this part could add twisting effect and make matters worse without.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
I think you need to beef it up
There is a gap.. or was a gap between the door frame and our door on the tall rear out side locker.. I had to jemmy it open once when something dropped down and james the key .. now enclosed so it cannot happen again.. I added metal strips to the frame in the inside of the jam so it made it much hard to get anything in to force it open...
Because it looks easy to open, doe not mean you should invite theft.
Today I spent £36 on locked for my trailer wheels.. cost me a lot more to buy new rims and tyres if so light fingered person wanted to jack it up and nick the wheels.. so I have made it less attractive.
I agree with Peter JCM you may find it is a job for an expert.
Bob
