Adding an external locker door (1 Viewer)
Apr 9, 2013
663
373
Ayr
Newbie
Has anyone done this? The underseat area at the back of our van would be a lot more usable if it were accessible from outside. I'm thinking about fitting one like this.
Link Removed
Are there any "gotchas" to a job like this?
Tim
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
Yes...
We used to have an Autotrail scout that had external lockers on both sides. Very handy. Later changed to an Apache 700 which was same layout but only had 1 locker.....
I bought the door frame like the one you have shown.. Not brave enough to do it myself so went to Dave Newell ( funster).. It was Dave's first one that he had fitted but did a great job and was well pleased.... Measurements were critical as it was very close in the space... The cut out piece of wallboard makes the locker door.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Cutting the hole a inserting the frame, should not be a problem..
Problems start in where to put it... under floor level will need a lot of thought regarding fixing the actual locker... and how bigger locker you can put in the free space..
Level with the floor... have you got the space to put the internal parts of the locker, or if utilising an under seat area is it worth all the hastle if you can already get inside this locker from the inside..:RollEyes:
For some one doing a self build, I should think it would work well.. :thumb:
timdownieuk
Apr 9, 2013
663
373
Ayr
Newbie
Thanks, it looks like some careful measuring may be required but doable. Fortunately, the closer I look at our van the more I realise that it's no newcomer to modifications so I'm not too worried about spoiling an "out of the factory" look. :roflmto:
Dec 6, 2011
11,589
25,417
South Wales
Coach built Adria
measure [STRIKE]twice[/STRIKE] 12 times cut once!:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I put a different type of door in our last van.
It was a case of measure, measure and measure again before attacking the wall with a drill and jigsaw. I even got a mate to help double check the measurements!!!! :Eeek:
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
Link Removed
Tim
Check the link in my signature picasa tinsnail
Measure and check everything before you cut or drill a hole
Be prepared for a lot of polystyrene dust no problem with it
But it's a right burger to clean up !!!!!!!?????
Once you drill the first hole your committed to finish
Make sure you have everything to complete the job
Including sealant ( sikaflex )to seal and secure the door/ flap
Oh and the best of luck
:thumb::thumb::thumb:
