Currently have 2 habitation batteries and replacing them with 3 new ones. The Elektroblock is protected by a 50 A Maxi fuse close to the 2 existing batteries.
To wire these new batteries in parallel I'm thinking of using 10mm2 cable with a length of around 70cm for each cable to the third battery, does that sound about the right size or should I go larger?
A few weeks after installing the batteries I'll be adding solar to the charging system with a Schaudt MPPT solar regulator and it's designated connecting points into the Ebl, would that alter the method of wiring the 3rd battery?
Thanks a lot
Thanks a lot
