Adding a new 12v socket
Discussion in 'Tech/Mech General' started by martin1485, Nov 13, 2013.
  1. martin1485
    martin1485 Funster
    Jan 26, 2010
    443
    666
    Conwy, North Wales
    I want to fit an additional 12v socket to power a TV. Is it safe to splice into the feed off another (nearby) 12v socket or should I run the cables back to the power supply unit which is more involved?
  2. Wissel
    Wissel Read Only Funster
    Sep 16, 2013
    301
    323
    Cornwall
    You can splice it of the existing one.
    The only problem you could have is if using both sockets at the same time with high draw appliances. As one is going to be a TV with shouldn't be a high draw you should be fine.
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,930
    I added a 12v socket purely because of convenience, we didn't have one near the table. Happily for me a nearby socket used spade connectors so I used piggyback spade connectors to connect the new cables in.
    The original socket is hardly ever used and certainly not at the same time as the new one.
  4. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,638
    14,305
    North Lincolnshire
    I went straight from a battery.
    Not for any other reason than it was closer than an existing feed.
    I use it to power the tv and satellite tuner with no problems, so you should be ok with either method.
    • Like Like x 1
  5. dogman
    dogman Read Only Funster
    Oct 24, 2013
    551
    444
    chepstow
    Can't see a problem with that, inline fuse will see it safe enough.
  6. motorhomelover
    motorhomelover
    Jul 28, 2010
    1,719
    613
    The world
    To be honest with you
    Best plan is get an Auto electrician
    As a little knowledge is dangerous
    Seen a van go up in flames. Just be wrong wires
    So unless your qualified. Keep your fingers off
    We should have the same laws on motors as we do now on house mains electricity :RollEyes:
  7. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    If you add another socket to an existing circuit you might overload the circuit protection, but that's what it's for to protect the wiring. Your only problem would be fuses blowing from time to time, or not, if you are careful about what you plug in to both outlets, as said earlier.
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,519
    9,942
    ive noticed over the years that most converters use as thin a wire as they can get away with to save money. be sure if you do splice into an existing circuit that the wiring is capable of handling the load
    you may remember initially to not use the other socket when the tv is on, but may possibly forget later
    oh and a bit of advice, fit a switch to the circuit as some 12v capable tvs still draw a current when on standby. you would be draining the battery whilst not watching tv :thumb:
  9. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,638
    14,305
    North Lincolnshire
    Forgot that.
    Yes, in line fuse fitted.
