Added sliding window security
Discussion in 'Motorhome Chat' started by TheTwoOfUs, Jan 13, 2012.
  1. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,593
    7,156
    South Yorkshire
    Here's a simple, inexpensive way of adding a bit more security to your sliding windows. All I've used are items readily available from most camping shops, namely 19mm and 16mm aluminium tube, 16mm plastic c-clamp, walking stick rubber and a thumb screw clamp. If you don't need any adjustment, you can do away with the thumb screw clamp and the 16mm tube and just cut the 19mm tube to length.
      File size:
      92.8 KB
      114
      File size:
      84.1 KB
      105
      File size:
      81.5 KB
      104
    • Like Like x 6
  2. gypsylady
    gypsylady Read Only Funster
    Jun 24, 2008
    251
    104
    Durham
    I worked in a school with similar window security.
    Someone had put a length of wood up against the sliding window so it couldn't be opened from outside.
    It Worked
    June
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    you beat me to it :cry:
    economy version......a strip of plywood laid in the window glass channel.
    • Like Like x 2
  4. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    And me ! I have only ever used a bit of dowling
  5. weekenders
    weekenders Funster Life Member
    Apr 30, 2008
    2,172
    1,229
    Leicestershire
    We use a strip of wood as well, lot cheaper!!
  6. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,183
    455
    wednesbury.westmidlands
    we use a cricket stump ,everything should have more than one use :RollEyes:
  7. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,537
    5,621
    Near Mold North Wales
    Thanks for posting the tip:thumb:
  8. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,593
    7,156
    South Yorkshire
    You use what you want, I am only showing people what I've done. It's up to them to decide which option to go for - if indeed any. However I will point out that one of the reasons that I did it this way was because the C clamp clips into place around the window edging whereas a piece of wood is simply spragged between the two. It can therefore be dislodged by a thin piece of metal inserted between the two sliding windows, similar to how they used to insert a something to unhook the door lock knobs. Also, I can if I want, leave the sprag in position when I'm driving safe in the knowledge that it wont fall out.
    Anyway, it was a simple, cheap piece of equipment that anyone can make using nothing more than a hacksaw.
    • Like Like x 2
  9. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    Hi I have used square wood dowling that drops neatly in the window channel I added a notice board pin to help remove the timber.
    [​IMG]
    [​IMG]
    Regards Pat
    • Like Like x 1
