Acsi to Copilot
Discussion in 'GPS Navigation' started by goldenline, Oct 12, 2015.
  1. goldenline
    goldenline Read Only Funster
    Jun 6, 2012
    133
    1,383
    Port Grimaud France
    does anyone know how to add Acsi to poi on copilot which I have installed on my iPad . Thanks. Alan
  2. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    977
    596
    Falmouth, Cornwall
    Where did you get the POI file, and what format is it in?
  3. goldenline
    Jun 6, 2012
    133
    1,383
    Port Grimaud France
    I only have the Acsi app on my iPad and have downloaded copilot to see what it is like and wondered if it is possible it to work with copilot
    Alan
  4. sallylillian
    Oct 29, 2011
    977
    596
    Falmouth, Cornwall
    You can get any POI file to work if you know how. CoPilot needs a .csv file (comma separated) . It needs 3 columns, with header labels in row 1, of Longitude, Latitude and name. Sounds complicated but easy. You will find that Garmin are CSV and others but using an online conversion you can convert almost any POI file to csv. Then open it in Excel or any spreadsheet program to check the column headers or add them if not there. So having now got the file you drop it into the folder within the CoPilot folder on your root directory. I know Android but not Apple, however you should have a folder EU and within that a Save folder drop in there and start CoPilot. It will find them and take you through the options of creating a new POI group. So if you are deciding whether to buy on the basis of adding your own poi's it is easy once you get used to it. I have for example created my own map of sites in Google maps, save out of there as KML and convert to .csv, and then follow above. I have added Archies, MyLPG, Spanish Aires, and other files in a similar way. If you have icons they can be added and associated with your new POI set. If you get it wrong just delete the file in the save folder and the equivalent file created by copilot in user (I think thats the folder). Hope this helps?
    • Like it Like it x 1
  5. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,673
    Ecclefechan
  6. goldenline
    Jun 6, 2012
    133
    1,383
    Port Grimaud France
    Thanks for the info will give it atry
  7. sallylillian
    Oct 29, 2011
    977
    596
    Falmouth, Cornwall
    It probably wont work on a trial version I suspect.
Similar Threads
  1. Figaro
    8
    470
  2. Ebby
    19
    407
  3. numpty76
    4
    464
  4. Manic
    24
    1,002
  5. AndyJJDavies
    83
    4,328
