Acrylic window cracks (1 Viewer)
christophe65
worcestershire
lo-profile
since 2010
I have had a Chausson Allegro 96 from new (March 2010) and after 12 months it started to develop cracks around the Dometic (Seitz) window catches. The dealer has informed is that Chausson will not replace these under warranty because they are due to chemical cleaning. We have only ever used warm water and a chamois leather to clean as we are well aware of the crazing/misting problems with the use of inappropriate cleaning products. Has anyone else had a similar problem and was it rectified by the dealer..or am I being blagged??
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I have had a Chausson Allegro 96 from new (March 2010) and after 12 months it started to develop cracks around the Dometic (Seitz) window catches. The dealer......
And that is as far as it goes legally. You<-->Dealer. He is responsible for the contract. If you are sure it's not your fault go for him via trading standards and/or small claims court. You should win. First write a polite letter telling him you have no option if the problem is not fixed FOC.
C.L.S
Trader - Service & Repairs
Jul 22, 2007
438
60
Not long enough
I have a customer with exactly the same problem , because it happened after 12 months the window supplier would not cover under warranty. After disscussions with the manufacturer, finally managed to get it replaced under goodwill.
I would put pressure on your dealer and see if they would be willing to absorb the cost of replacement as a goodwill gesture.
Mark
Terry
11,923
9,026
Lincolnshire
Can't remember ;)
The onus is with the dealer who in turn should get onto Chausson who would then get onto Seitz If anyone can be bothered that is :Sad:put pressure on the dealer who then may put pressure on the others :winky:
terry
