Acceptable Damp Level (1 Viewer)
Cavendish
204
England
Since September 2008
What level of damp is considered to be acceptable?
Matt took the van to be serviced today at Discover and it was mostly 10-12% apart from one reading on a small section of floor by the door which was 18%. Discover have said 18% is nothing to worry about. Unfortunatley I have no faith in this wretched company whatsoever. Have we been twirled again or is it ok?
haganap
12,758
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Hi Claire, Got this of a website I used a while ago. sure nothinghas changed in 4 years
Readings between (0-15%) no cause for concern
Readings between (15-20°10) dealer to make a note of these readings and re-check at next service.
Readings between (20-24%) possible early signs of ingress, look for tangible evidence or ask for a re-check.
Readings between (25-30%) moisture evident, remedial work required; may not need stripdown unless surface damage (staining, pimpling, and softness) is apparent. (There is a risk of wallboard deterioration due to retained moisture in the structure if resealed only.)
Reading (31 % and above) structural damage is occurring, deterioration inevitable. a full stripdown of the affected area is required.
Hope this helps:thumb:
C
Cavendish
204
England
hokie cokie, we'll keep an eye on it. :thumb:
