ABS Brake System (1 Viewer)
f6c
Nov 7, 2010
10,960
4,792
gloucestershire
Carthago Malibu 640
23 Years
Can any one help.
Whilst driving back home in my Auto-Trail Chieftain the abs warning light up on the dash board display. The brakes are working OK. What the best course of action?
Many Thanks:Sad:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
^^^As Peter says, a dirty sensor - or it could be the abs sensor wire broken - they are quite long on these, and if they have become detached from the clip, will snag and break. Strip and solder back together.
Sep 29, 2009
198
60
norwich
swift escape 640
since 2009
a good guide is to watch dash abs warning light when switching on ignition
expect to see it iluminate then go out after a few seconds[as usual]
if light remains on expect a main sys fault
if light goes out as normall but returns when moveing off or up to aprox 25mph you can expect a wheel sensor or cracked sensor ring [poss caused by recent weather]
as said a fault code read hopefully will identify more exact problem
hope this helps glyn
F
f6c
Nov 7, 2010
10,960
4,792
gloucestershire
Carthago Malibu 640
23 Years
abs braking system
Can any one help.
Many Thanks:Sad:
Had a diagnostic test done today, in read 0006 incorrect number of teeth.
Any ideas what this means?
Many thanks for all your help.:Doh:
Feb 25, 2008
232
96
Barril da Alva, Portugal
Caravan
on and off for the whole of my existance
stupid suggestion
Have you checked the amount of brake pad left as on some vehicles the warning light also tells you your pads are getting low........
Hope it is this simple....
Good luck...
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
It may be making referance to the sonic ring that the wheel sensor uses to gauge wheel spin and activate the ABS
This ring has teeth on it with a gap that looks like one tooth is missing
Its possible the gap has filled with dirt and the sensor is seeing what it thnks is another tooth,
Or the ring has cracked open slightly and the spacing is wrong, or the pick up is faulty you need to check all the wheel sensors
The chap with the diagnostic machine should able to tell you which one is giving the fault if completes the diagnostics
The code appers incomplete any hoo:Doh:
Sep 29, 2009
198
60
norwich
swift escape 640
since 2009
sorry seems an odd code
i would expect a letter at front ie P or C and the numbers do not match my reference
as a further point for thought sometimes a mismatch in tyres due to wear or makes can cause a fault did you have a tyre changed ??
glyn
F
f6c
Nov 7, 2010
10,960
4,792
gloucestershire
Carthago Malibu 640
23 Years
Hi Glyn,
No work has been carried out on the van for the last 6 months.
Booked the van into Hereford motor-home centre first week of February.
Many Thanks,
To You All:winky:
