A solution to rear TV speakers (1 Viewer)
Chaumo
162
163
Gloucestershire
A few years
Our Avtex TV has rear facing speakers and is mounted on a swinging arm. When we slommock about on the beds at the rear we have to increase the volume as the tv does not back onto anything. To resolve this we tried some Bluetooth speakers with apt-x ( this being an acceptable standard to reduce audio to vision time-lag) and a bluetooth transmitter with apt-x plugged into the earphone socket of the set. Everything worked but the time-lag was still unacceptable. In the end we opted for this weeks bargain:- Broken Link Removed
2 tiny speakers joined by usb cable that plugs into the head phone socket. No need for bluetooth. Excellent sound. No sound kicking out of the rear of the tv. The cable also charges the speakers.
CWH
5,145
247,398
UK
WildAx PVC
From November 2013
Excellent tip! We have the same problem. We have a set of speakers hanging around somewhere, I'm going to try this tomorrow!
Thanks @Chaumo ! :)(y)
Dec 6, 2011
11,588
25,407
South Wales
Coach built Adria
have the same problem, we now use the KS Hive; great sound, compact ; hard wire or bluetooth and can be used with your phone as it has a mic.
Lenny HB
53,412
149,887
On the coast in West Sussex
Hymer B678 DL
Wired ours to the head unit in the dash, using the vans 6 built in speakers gives much better sound than any of these little speakers and no batteries to replace.
Jan 2, 2015
2,470
8,626
Cumbria
Burstner Solano t725
since 2014
I have been looking for a solution to this problem for ages. Thanks for the tip
Just to make sure I am reading this correctly....
If I get a 3.5mm jack male to male cable , plug one end into the headphone socket on the TV and the other to the AUX socket on the van radio, select AUX on the radio should the TV play through the van speakers?
mentaliss
654
306
Lancing
C class
_______________________________________________
We had the same problem September last year, as with most LED/LCD TV's) audio comes from the back of the unit as does most TV's bought for the house hench the marketing of the so called 'Sound Bars'. We sorted this by mounting our 19" cello TV on a drop down bracket fixed to the ceiling at the end of the transverse bed, wired in a Laptop 'Edifier' 3 Speaker system (subwoofer, two side speakers) connected to the Earphones TV out 3.5mm socket, we may introduce an in-line headphone amp to enhance the volume...also now looking at replacing this sound system with our just recently purchased Samsung Sound Bar..and so on...
Nov 3, 2014
194
107
Devizes, Wiltshire
Coach built
For ten years
Hi there just picked up speakers
And tried them proper job thanks again for the tip.
Jul 29, 2013
9,071
18,506
Salisbury
Hymer B678DL A class
since 2011
@lennyhb Any details as to how do this would be much appreciated thanks Lenny in anticipation.
Lenny HB
53,412
149,887
Hymer B678 DL
I drilled a hole in the floor under the kitchen unit and routed the cables along and across the chassis and back into the cab via the battery box. I used split flexable conduit to protect the cables, my reversing camera cable takes the same route.
Jul 29, 2013
9,071
18,506
Salisbury
since 2011
@lennyhb Thanks Lenny going to take a look and see if Ican do likewise.:xsmile:
