A Quickie for frustrated Funsters (1 Viewer)
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi folks here is a quickie question. I’ve just filled my water from empty and boiler with cleaning chemical which is suitable for stainless steel boilers.
I’ve run the taps to clear any air and now it’s sitting there with a full tank of water and taps closed.
My question is do I need to run the boiler and heat the water in it, there is no mention of this in the instructions but seem to remember reading it somewhere.
The other simple question is when I come to drain the water do I just open the tank drain cock and boiler drain or run it down through the taps, or a bit of both?
Many Thanks Tony
9,762
20,115
Newcastle under Lyme
Hymer B544 A Class
Since 2015
That first sentence could be considered an inappropriate comment given the pampas grass thread currently running !
movan
21,492
120,753
Moving around
Burstner
since07
... and the last question ... open all taps as well ... means it twice as fast draining plus any water in pipes will come out and not freeze ... but remember to turn taps off if pump still switched on.
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Figaro not sure what you mean but not to upset anyone I've changed the first sentence.
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Figaro can you please post a link to the thread you are talking about so I can understand what I might of done wrong.
Many Thanks Tony
movan
21,492
120,753
Moving around
Burstner
since07
Many Thanks Tony
You have done nothing wrong. Figaro is joking .. about a thread and quickies in laybys.
Jim
Ringleader
Jul 19, 2007
36,324
130,305
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Nothing at all, Figaro could have made it plainer he was joking or provided a link. :)
Meanwhile I wouldn't heat the boiler, just run the taps when its time to drain down, You will have a low drain tap for your fresh water, check your handbook to discover it. That will ensure everything is out, you should then flush it a few times incase there is any residual. (y)
Feb 22, 2011
9,762
20,115
Hymer B544 A Class
Since 2015
@movan right, just a joke, I can't post a link on phone but scroll down through Recent and look for a title thread called pampas grass.
Very enlightening !
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
I don't know what you have used but I use white wine vinigar and always heat the boiler as it is a lot more active when hot.
Hi Lenny
I used something called Puriclean which is a powder and was recomended to me by a friend, my friend said it works well and leaves no after taste an he uses it every time he cleans his system.
Best Wishes Tony
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I think the puriclean you talk of is for stored water cleaning. Not to be confused with boiler descaler.
You should draw the product through your drinking water pipes. It won't do any harm drawing it through all the pipes.
I would draw the whole tank through the pipes and then draw a tank of fresh through to rinse.
It may also be a good idea to fill with fresh and drive to slosh around, before draining
Jim
Ringleader
Jul 19, 2007
36,324
130,305
Sutton on Sea, UK
Adria Panel Van.
Since 1988
If you are desacaling then Truma recommends five litres of water with five litres of white wine vinegar poured into the fresh water tank and that this mixture is then run into the boiler. The water should then be heated up to the maximum temperature then allowed to cool down again before you do a couple of thorough rinses (y)
Jun 30, 2010
7,924
27,228
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
/QUOTE]
Puriclean cleans and sterilizes
Aquaclean keeps your stored water fresh
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Would 10 litres of solution be enough for the boiler to work? Wouldn't 5 litres of white vinegar be expensive?
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Jim that looks like it's my next job then, now to look for 5ltrs of white wine vinigar. perhaps as EX51SSS is saying I might need more liquid to do this!
Many Thanks Tony
Jim
Ringleader
Jul 19, 2007
36,324
130,305
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I've never bought any or descaled a boiler, I'd have thought you'd get the vinegar for less than a tenner
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Ah right. I'll see if I can find out the sort of minimum amount of water I'd need in the tank. Thanks Jim
Aug 27, 2009
19,788
23,049
Hertfordshire
Van Conversion
40 years
Quickies in laybys and old boilers, is their a link here somewhere....:)
Lenny HB
53,315
149,512
On the coast in West Sussex
Hymer B678 DL
Hi Lenny
Best Wishes Tony
I think Puriclean contains choline so should not be used in a Truma boiler.
HOW MUCH!! 30 cents a litre in French supermarkets, always stock up when over the water.
I now understand Truma recommend citric acid rather than white vinegar.
Truma used to recommend white wine vinegar but since they bought out their own product they now recommend that.
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Lenny found this on their site.
Is chlorine dioxide a chlorine?
Chlorine dioxide is not another form of chlorine the two compounds are completely different.
Chlorine dioxide has “no elemental free chlorine” and can be used to eradicate the taste and odour of chlorine. It has world-wide approval for drinking water, high efficacy against bacteria, fungi, yeasts, algae and protozoa. It has little or no effect on human, animal or fish cells.
PURICLEAN CAN BE USED IN ALL WATER SYSTEMS INCLUDING THOSE WITH STAINLESS STEEL BOILERS
Best Wishes Tony
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Now here's a question.
I cleaned out the fresh water tank with Puriclean, this morning I started to drain it down closing off the waste water tap as I thought I could fill the waste tank up and clean that tank as well.
So I drained the remaining fresh water tank and the boiler drawing most of it through the taps, a bit of crap came out but nothing much.
I closed the fresh water drain and the boiler drain and refilled the tank with fresh water and drew some fresh through the taps and the boiler. I then went for a drive to dissolve any residual Puriclean in the fresh water tank and also give the full waste tank a shake about.
When I got back I started to drain the fresh water tank through the taps, to my surprise it looked like grimy river water,
I continued draining through the taps hoping the situation would clear itself, it did not.
I'm going to give the MH fresh water tank another cleaning tomorrow and hope that sorts it out.
Is there any possible way waste water could get into the fresh water tank, remember When I drained the fresh water tank I filled the waste water tank to the top to give it a clean.
I know it sounds strange but that is what I think has happened by me filling the waste water tank to overflowing.
Anyone know if these tanks are speparate or one tank devided, and are they metal or plastic.
Any offers?
Best Wishes Tony
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
H
aving a swinging time then.
The heater will make the system cleaner a lot more active than plain cold water. but do not just leave it in for a long period or it will settle in places you do not want it to.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Thanks Movan
the last thing I want to do is upset someone, everybody nowadays seem to sensitive and quick to get upset at the least little thing.
Anyway thank. Tony
They are not upset they just have funny habits, you should try a wind up if you want to see them rise to the bait. Hence the fishing imoji.
