A frame servicing Lancashire (1 Viewer)
My Dog Likes Fishing
379
407
Lancashire
Hymer B678
Hang on while I look at my watch
Need some help please.
Can anybody recommend a place to get my a frame serviced in the Lancashire area.
In particular I require a new brake adjuster cable. Anybody know where I can get a new one please?
43,319
49,372
there isnt really anything to service except a squirt of grease in the sliding hitch nipple and a drop of oil on the handbrake linkages.
The cable will be A frame manufacturer only i reckon.
haganap
12,757
26,436
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Ill follow this with interest.
My aframe brake cable has snapped at the part it attaches to the brake pedal....
presumably that will be a measured up part, so may have to contact towsure as they fitted it initially.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
you may be able to shorten the outer cable and fit a fixing with a grub screw . chat to an AAman they carry lots of ends .
they can make most cables ,
Oct 31, 2012
256
516
here there and everywhere
Pilote P650
Since December 2012
Try Barlow Trailers near Leyland. Here are their details. They are a main Ifor Williams Agent ( I think) I used them once about 10 years ago, when I was still working. My Boss needed some parts for his Trailer. I'm sure they would have the parts you need. ::bigsmile: BillyS
Address:
John Barlow
t/a Barlow Trailers Ltd - Ifor Williams Main Distributor
Southport Rd
Leyland
Lancs
PR26 8LP
Telephone:
01772 600395
Fax:
01772 601389
379
407
Lancashire
Hymer B678
Thanks for your help everybody. I'm going to make some calls with the numbers provided.
Will update later.
43,319
49,372
bear in mind the brake cable is different to any other.
Caravans are normally rod operated to the axle then cable to the drums.
The pedal end is designed to fit the pedal and the length is important......too short and it wont fit...too long and you need to lose the excess length without kinking it, and that aint easy under a car bonnet
Ring the manufacturer..they are only a few quid.
