A-Class owners - how do you reach your nuts? (1 Viewer)
Apr 12, 2012
240
97
Fleet, UK
Pilote Atlantis 34
MoHoing since 09/04/12
Wheel nuts, that is.
I have another simple job, that has turned into another PITA. :cry:
I wanted to get my wheels off to repaint prior to fitting some sexy new wheel trims. Only it turns out the wheel nuts haven't been off in an awful long time and are quite badly stuck.
Being as the wheels are quite far recessed under the van, it's really difficult to get any purchase on the wheel-wrench-bar-thing, and it hits the body work - and there's no room to apply my torque-multiplier (metal leg off the pedestal table).
Anybody got any top tips or recommended equipment for getting my nuts off??
Many thanks as always
Jamie.
Pikey Pete
1,481
1,143
o
o
Go to your local tyre fitters (not one of the Nationals) and ask them to loosen the nuts, with their air guns.
Pete:Cool:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I carry a long breaker-bar, a heavy duty socket to fit the nuts and an extension bar that extends beyond the bodywork. To do them up again, I switch the breaker-bar for a torque wrench.
43,301
49,286
to reach the recessed nuts properly you need a socket, an extension bar, a breaker bar and an axle stand.
place the socket, extension and bar on the nut...adjust the height and place the axle stand under the end of the extension bar.
you could use small wooden blocks instead of an axle stand.
that way you can stand and jump on the bar without risk of the socket coming off the nut.
only re-tighten the nuts with a breaker bar, or more correctly, with a torque wrench......never with a 'windy' gun (air powered impact gun) as there is little chance of getting the torque correct and over tightened nuts can be just as dangerous as under tightened ones.
jamieBG
Apr 12, 2012
240
97
Fleet, UK
Pilote Atlantis 34
Ah - the axle stand bit sounds like a good idea.
I have various socket extensions and bars, but it all feels a bit rickety when linked together - an axle stand to rest on sounds like a fine idea.
I will try that this evening.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi, best use 3/4 inch or even inch sockets etc . 1/2 inch will probably break like cocktail sticks .
jamieBG
Apr 12, 2012
240
97
Fleet, UK
Pilote Atlantis 34
Got 3/4".
Axle stand did the trick - I've been able to crack them all off.
But bloody hell they go with a bang when they finally give in!! I thought either my bar had snapped, or my socket had exploded, or the bolt had rounded off, but no - the tougher ones gave an almighty bang and then gently unwound.
Thanks as ever for the timely advice Funsters ::bigsmile:
What's your views on the use of Copperslip to prevent this sort of thing happening again?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i forgot 6 sided sockets are best.
i broke a 3/4 flexy bar only the other day . it was brand new . sent it back . but shant use a flexy bar will stick with the sliding t bar.
43,301
49,286
Got 3/4".
I use a little copperslip on the threads only...not on the nut/wheel seating face.
