A Cautionary Tale Re Ehu's
Discussion in 'Tech/Mech General' started by cydersyd, Apr 28, 2015.
  1. cydersyd
    cydersyd Funster
    Jul 21, 2010
    266
    351
    Sherborne, Dorset
    While on a site in Spain during the winter I was visited by some friends. Knowing which pitch they were to stay on I laid out my spare EHU cable for them to use on arrival. They stayed for a few days but when they came to leave, and as usual, removing the EHU was the last thing to do my friend was unable to physically un plug it from his van. Everyone around tried with no avail and we ended up detaching the connections inside the van and removing the whole box in which the connection is made.
    Previously in the uk I had been using this cable over a period of about a month at home connected to my van to keep a convector heater working during a colder spell.
    On arrival at Hispavan in Vera, the engineer tried to disconnect the cable with little success until he attacked it from the rear. He eventually realised that the female socket had welded itself through the live connection to the male pin.
    An autopsy was carried out after it was all disconnected and found that the live connection in the female socket had become loose and arcing had taken place, welding it to its appropriate connection.
    I know this isn't a daily event, but nevertheless it may be wise to occasionally inspect the connections in well used EHU cables. There isn't much to grip on the socket when pulling it out from the van and it could be that the cable takes some of the strain potentially causing the connections to be compromised.
    • Like it Like it x 11
  2. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    Thanks for pointing this out, as you say, probably unusual but worth checking now and then.
  3. hilldweller
    Dec 5, 2008
    27,551
    26,638
    Macclesfield
    Ah yes, I remember it well.
    • Like it Like it x 6
  4. JJ
    JJ Funster
    May 1, 2008
    14,893
    26,701
    Wouldn't have happened if you just used generators!
    JJ :cool:
    • Like it Like it x 7
  5. parknride
    parknride Read Only Funster
    Jan 21, 2014
    2,111
    4,852
    cumbria
    Someone mention generators? Do you recommend them?:giggler:
  6. PeteH
    PeteH Funster
    Nov 22, 2007
    2,214
    2,760
    East Yorkshire
    (Very) long thread elsewhere?.
    Pete
  7. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    262
    182
    Rushden, Northants, UK
    When terminating cables in sockets we use bootlace ferrules crimped to the conductor.
    Tightening the screw doesn't cut the conductor strands and generally we have much less trouble with loose connections.
    Peter
    • Like it Like it x 4
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,492
    6,481
    West Sussex
    Should really check the cables once a year but do we! I know I've got cables around I made up 20 years ago must admit never checked them, I rarely use hook ups but after reading this I might just go and check them.
  9. Fireman Sam
    Fireman Sam Funster
    Sep 8, 2012
    1,546
    2,515
    Bushey
    And don’t forget that with high-resistance heating and arcing you can have a fire.
