funflair
Following on from the Battery Master fitting I had another little job on the go as well. We were away at the weekend and the fridge and heating were not working on 240v although the battery charger was and the sockets in the bedroom were, on our van the circuits are split so I went straight to the 240v trip and distribution box and pulled a couple of plugs out and one of the was a little bit brown were it had got too hot so I had a closer look (it was in one piece before I broke it)
OK so this is the plug with the terminal PINS in it.
AND this is the socket SPOT THE MISTAKE yes its got pins as well? I will add this is not N+B wiring as somebody fitted an inverter years ago before we bought the van, so its done pretty well to work this long.
So I have the spare plug and the correct terminal tubes now but need to find somebody who can do the special crimp.
New tube (female) connector on the left and the old (male) pin on the right showing that the crimp is not just an old pair of pliers job.
Martin
EDIT hopefully the job wasn't done by a professional electrician.
Martin
