60mm grey water hose
Discussion in 'Motorhome Chat' started by gwilliam, Jun 19, 2010.
  1. gwilliam
    gwilliam Read Only Funster
    Jun 19, 2010
    5
    My CI has a grey water outlet tucked well under the 'van, it measures 60mm diam (external) and is proud by a mere 25mm. I want to add a couple of meters of flexi hose to it to make draining on site easier. None of the local DIY's stock any hose bigger than 50mm. Has anyone solved this problem?
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi gwilliam
    Welcome to MH Fun
    My van has same sort of waste disposal but have never found it a problem, more sites nowadays are allowing for this set up and I just carry waste to next site.
    The only way I have seen someone get over this was to carry a rainwater hopper with legs to stand under waste outlet.and flexible hose attached to that, seemed to work for him.
    Dave :thumb::thumb:
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,427
    East Sussex 01-580-881288
    I think that you will find that although it is described as extremely flexible as regards an exhaust system it will not be suitable for a water drain hose under the van.
    We dont list a 63mm hose on the website but it might be worth giving Ian in our parts dept a ring as they may have some.
    Peter
  5. redpis
    redpis Read Only Funster
    Mar 8, 2009
    24
    Hi,
    I have been after a peice of fire hose for ages, thats 64mm diameter and would do the job just fine me thinks, (held on secure with a cable tie) , asked all over the place for an off-cut and looked on e-bay for a while but to no avail.
    This post has re kindeled my interest.
    If I manage to get some I'll post up and share the love :)
  6. 747
    747 Read Only Funster
    Oct 4, 2009
    20
    Tyne and Wear
    Try a Plumbers Merchant for the hose. I doubt if they will have that diameter in stock but they will have a catalogue.
    Before I retired, I worked with all diameters of flexi hose, so there will be some out there.
    I renewed the flexi on my Burstner and made up a piece of plastic drainpipe to connect them together. The catalogue showed an adjustable (swivel) 90 degree bend which sits between the flexi and rigid pipes. This gives me a movable drain. The plastic drain is 1.5 metres long and it is all a push fit together. I only need to connect it up now and again but it has made draining the waste tank much easier. On site, I do not have to mess on being inch perfect when driving to the waste disposal point.:BigGrin:
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,121
    17,789
    YO11 2BD
    try an electrical wholesalers (they all have a general public counter)......many sizes of flexy wiring conduit.
  8. 747
    Oct 4, 2009
    20
    Tyne and Wear
    The electrical conduit idea may give a smell problem as it is not smooth internally like the correct type of flexible water hose. At 60 mm dia, that is a lot of pong that can accumulate.:Wink:
  9. Wintonian
    Wintonian Read Only Funster
    Nov 30, 2009
    122
    Brittany, France
    The problem with fire hose is that it is "lay-flat" hose. With high pressure water flowing through it it becomes round, but with very little water pressure, if it turns through any angle it will flatten and constrict the water flow.
    To extend the outlet to a more easily accessed valve, a solution using rigid PVC pipework would seem the best solution.
    On my old Hymer, the outlet hose is a smaller bore - 20mm - so an extension is not a problem, and, of course, the extension hose is stored in the rear bumper. Hymer were very clever to put those spring-retained end caps on there. Fishing rods and other slender items can be carried in the alloy extrusion.:Smile:
  10. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    cak tanks do a range of fittings for waste pipe.
    mine has a bayonet fitting of around 60mm external.
    just got the socket end if you will and some 50mm pond pipe form the local aquarium shop.
    sorted.
    the pond pipe is ridged on the outside but smooth inside.
    this may work for you :thumb::thumb:
    andy
