5th wheel levelling legs problems
Discussion in 'Fifth Wheelers' started by cotajokial, Jan 28, 2012.
  1. cotajokial
    cotajokial Read Only Funster
    Sep 6, 2011
    4
    Dunstable
    I am having lots of trouble with 5th wheel company, dream seeker fitted with Atwood Level Legs with Auto function.
    When to pick up from storage and legs retracted as per normal. Once at site could not get front legs down as instructed bu the manual. EXT-ALL-FRONT. I could only get them down by holding EXT-ALL-FRONT, but then they would only extend for 10 seconds or so before having to release and press all three again.
    Once front legs down, Truck unhitched, and pressed AUTO function and REAR legs would not extend either. Could not even get them to extend manually by holding the buttons as I did on the front.
    Left batteries to charge fully and tried again this morning, same results. Checked all fuses, all good.
    Both Front legs LED,s flashing green, indication extended? I know they are not full down.
    Any ideas or advice much appreciated. Getting fed up now with poor support for very expensive camper!
  2. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    939
    cheshire
    we have a motor on ours but can also manually wind them down do the 5th wheel company ones not do this? I do know that using the elec wind down does take a lot out of the batteries and we tend to do a manual wind down.
    Sorry i can't help re your model and i dont know of anyone who has a 5thwheel company 5th wheel that i could point you to for help, most of us have either full yank models or calder or niche supplied units
    • Like Like x 1
  3. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,351
    1,439
    Suffolk
    Like Chatters, we also have a motor to run our jack legs, however, we are on a site in Southern Spain at the moment and there is a Celtic Rambler here on the site. If we get a chance to speak to the owners, we will ask if they have any solutions for you.
    In the meantime, go onto RV.Net (an American Forum) into the fifth wheel section, and put your query on there, I get a lot of info. from this site for our truck camper and fiver, it's also a free forum.
    Alternatively, have you tried the Atwood website, there maybe an answer there, hope so.
    All the best - we'll see what we can come up with, can't guarantee today though.
    Nigel and Pamala
    • Like Like x 1
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    You may have more luck with an answer from our sister site RVOC.
    it is purely an american Rv enthusiasts forum with quite a few 5th wheel owners.
    just like this forum, you get a few 'free' posts and if you want membership it is a mere £5 because you are also a member on this forum.
    its not as fast moving as here but you should have some answers within a few hours at most.
  5. Sundowners
    Oct 30, 2007
    2,351
    1,439
    Suffolk
    Have just spoken to the Celtic Rambler owner and he has come back with an instruction leaflet titled 'Atwood 5th Wheel Levelegs - Auto Leveling & Retraction'.
    On the bottom left hand side of this leaflet there is a paragraph that reads
    "If you go out of sequence, or press the wrong button by mistake, or in an emergency you will have to hitch the truck up to the fifth wheel and then Retract ALL and start from the beginning again."
    If you do not have this leaflet, you should be able to get one from the 5th Wheel Company as he got this when he had a problem when picking his up and they gave it to him, if not, I can type everything on it and pm it to you.
    All the best.
    Nigel and Pamala
    • Like Like x 2
  6. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    Good of you to take the trouble
    Nice to see someone take the trouble to try and help out a fellow traveller.
    refreshing...
    Bob:thumb:
    • Like Like x 1
  7. cotajokial
    Sep 6, 2011
    4
    Dunstable
    Many Thanks for all your advice.
    To update you all on the latest;
    I had to manually wind the rear legs down on arrival, and then back up today when we left the site.
    Front legs did retract electrically but only if the buttons held in all the time.
    We decided to take the 5ver back home to check things out as we are planning a trip some distance away. On arrival back home, front legs worked just fine. Un-hooked truck and Auto function worked Ok to!
    I have no idea why this is OK now.
    I will call Atwood in the USA and see what they say, and I will also hook up and un hook a few times and see what happens.
    Again, many thanks for all your help and advise. I will let you know if I find anything else out that might help.
  8. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    lets hope it settles down
    Lets hope it settles down soon so you can use it as you were hoping to.
    Atwood in the USA are very helpful I have found.
    Bob:thumb:
