4mm plastick sheeting
Discussion in 'Tech/Mech General' started by Wildbill, Mar 18, 2014.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    I am looking for plastic sheeting that can be shaped by heat gun any ideas
    it neads to be abut 8"
    was thinking can the plastic facia board be shaped by heat gun
    bill
  2. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    the missing trime
    [​IMG]
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
  4. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Perspex can be heated and re shaped if done carefully....can get that in B& Q and any good DIY store...
    If you need it white go to a model shop and buy some Styrene sheet in the thickness you want...
    • Like it Like it x 1
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    :thumb:
    thanks dose it com in 10ft x 8" boards I wonder
  6. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    No but Styrene glues very well, including butt joints...using the special cement mixed with superglue...
    I'm not sure you can get it in 4mm thickness though..
  7. Masman
    Masman Funster
    Sep 25, 2009
    313
    205
    south yorkshire
    Try. Local upvc companies they usually have lots of different sizes.
  8. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    can it be shaped by a heat gun thanks
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,716
    10,145
    UPVC cladding board can be shaped with a heatgun, but discolours easily, so you will have to spray it to suit. available in 5m lengths and various width including 250mm. being only a few mm thick, you would need to find something to form it over rather than freehand. maybe make the shape up in wood, just smaller than needed. lay the UPVC over it and warm it up, whilst applying a bending force. its likely to take some time and will need working in stages till its as required. from experience I have found that if not firmly fixed down bent UPVC tends to spring back a bit if it gets warm again. so may be best to do the trim in shorter sections
  10. Masman
    Masman Funster
    Sep 25, 2009
    313
    205
    south yorkshire
    Pop into local pvc place and have a word with the guys.they may even have a off cut you could try. Before buying any:thumb:
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,768
    6,290
    South yorks
    Hi Bill the thinnest the cladding guys will have is WESTBRICK cover sill at 3 mm x 250mm wide but it is very hard and stiff--I think you will need some 2mm door skin flat blanks almost 7 ft x 3 ft they are very pliable--- can you remember my back box? that was covered with a sheet but it has a wood-grain effect on it not smooth.They cost around 15 to 20 quid a sheet depending if they like you or not :BigGrin:
    I have a sheet of the wood grain stuff in my garage along with some 3 to 4 ft off cuts around 8 to 12 ins wide --will post a pic but don't know if the grain will show up =centre bit of box
    terry
  12. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,266
    12,991
    somewhere
    I will be making the shape with something like that then using fibre glass and body filer I will sand down and shape then spray it to colour it will be another DIY challenge
    :thumb:
