3mm Aluminium Treadplate (1 Viewer)
zaskar
1,159
371
UK
5th Wheel
Anyone know where I can buy sheets of it, preferably in the Cheshire area?
Cheers!::bigsmile:
scotjimland
2,288
9,916
A Woosh bang
You could try the larger B&Q stores, they stock all sorts of profile ally and sheet.. I bought perforated ally sheet for a new grill on the RV .. worth a look
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
Hi try asking at your local steel stockists,if you do not know of any ask the local gate / fence maker to put you in touch :thumb:
terry
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Try your local Landrover specialist, Landy owners seem to stick Chequer plate everywhere. There is some on E-Bay
232
96
Barril da Alva, Portugal
Caravan
on and off for the whole of my existance
Looking at the info provided you should source some easily.
Once you have it, if you need to cut it, use a jigsaw with medium size teeth. Use as good quality blade as you can afford, use jigsaw on a medium speed, this will help prevent heat build up and clogging of the blade. Good luck. If you have any problems, either sourcing material or cutting please give us a ring or pm me. Just a note, some grades of aluminium chequer plate will crack and brake when folded.
