Doesn't make any difference till you go over 3500Apart from the obvious (payload, fuel consumption) what would be the benefit of having a PVC plated at either 3300 kg or 3500 kg?
3500 gives you a bit of leeway should you put on weight.Certainly I was inclined to go for 3500 but was unsure of any legal or financial differences, thanks for your help and advice.
Careful there, cheeky! : )3500 gives you a bit of leeway should you put on weight.
Extra payload I mean of course.
Cheaper tax
High road speeds (if you need to)
cheaper tolls
Is it just a paper exercise to up plate from 33 to 35?
It will be for mine, too.Yes, it was for our Moho.
Thanks Dave. It's on a 5 meter Fiat Ducato chassis. I wasn't aware of the things you've mentioned (which probably means I don't deserve the van!) so that's all interesting and useful stuff. I wouldn't need to go any higher than 3500.The 3300kg one will be built on the light chassis, this means smaller brakes, smaller wheels and tyres and a limit to future weight upgrades. Yes you can probably take it to 3500kg on a paper exercise but to go any further will mean major upgrades req'd to tyres, suspension and possibly brakes. If everything else is the same go for the 3500kg version.
D.
Sorry, I didn't say that correctly, the van body is 5 meters, plus spare wheel on the outside of the back door. The converter (very reputable firm) will plate it up to 3500.It may be a 5 metre wheelbase but what is the overall length? In my experience a short wheelbase with a long overhang leads to a very unstable vehicle, "the tail will wag the dog".
D.
