3 way Fridge Gas button stuck (1 Viewer)
susan jane
Weymouth
auto trail tracker
I'm a newbie
The Gas button (the one that you press to allow gas to flow to the burner) is stuck solid and will not turn - is there any way to free this button or do we need to buy a replacement.
highwayman
968
1,029
Herne Bay
Low profile Rapido
Since 2005 ish
Hi Susan
Firstly, I'm no expert.
But does the button hit the facia when you push it in ?
If it does, pull the knob off and put a little bit of paper in the hole in the knob and replace.
This should hold it out so it clears the facia and should allow it to turn.
I only know this cos the engineer that serviced our fridge at Lincoln did it and mentioned that he'd fixed a couple that had your problem.
Cheers. Nige
S
susan jane
Weymouth
auto trail tracker
I'm a newbie
Hi Nige,
Thanks for your prompt response.
The button is stuck solid which prevents it being pushed in and also prevents it from turning.
Any advice would be gratefully received.
Sue
Hi Susan
Cheers. Nige
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Hi sue try a little squirt of wd40 then leave for a couple of mins before pressing a few times to try and release.
Vlad
