3 Months In From New Motorhome
Discussion in 'Introduce Yourself' started by Warmleys, Jul 15, 2015.
  1. Warmleys
    Warmleys Read Only Funster
    Jul 15, 2015
    5
    Bournemouth
    Hi, we bought our first motorhome 3 months ago and so are newbies. there are so many little things that you wouldn't have thought of before.one question, when our MH is on our drive should we leave it plugged into the mains? also, my hydrometer reading is 65 %, is that normal
    thanks in advance
    rob and odetted
    • Like Like x 1
  2. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,591
    11,491
    Kettering
    Hello :welc:
    Leaving it on EHU on your drive won't do it any harm.
    By hydrometer do you mean damp/moisture meter? If so unless you are using it whilst you're in the shower no it most certainly isn't normal. Over 20% is damp, over 50% is very wet. If you're sure you're using it correctly I think you need to go back to your dealer.
  3. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,944
    9,046
    Wrenthorpe, Wakefield.
    Hi here. Welcome to the club. You don't need to be plugged in.
    We never have. Though we've a solar and a trickle charger thingumbybob , all above my head. But it keeps things charged.
    As for the hydrometer , Ralph uses one of those to test the alcohol content of his home brew !
    65% is pretty strong stuff !!
    • Like Like x 4
  4. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,444
    15,113
    North Wales.
    :welc: Hello welcome to Fun , you don't need to leave your Motorhome plugged in when you are in your drive, it's what suits you. We generally plug ours in the day before we leave so we can load the fridge etc .
    • Like Like x 1
  5. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    428
    Worcester
    Don't need to keep it plugged in but it doesn't do any harm. We have a second EHU lead so I keep it permanently unrolled in the garage and it's a simple task to plug it in and switch it on whenever we get back from somewhere. Makes it easy to plug the hoover in ready for the next outing and looking to plug a dehumidifier in in the winter.
  6. Enword
    Enword Funster
    May 20, 2014
    707
    2,333
    Devon
    Are you checking specific gravity of your battery acid ??? (water and sulfuric acid solution)
    • Like Like x 2
  7. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    428
    Worcester
    A hydrometer is used to check the specific gravity of a liquid. Some common uses are battery acid, engine coolant (in both cases to check solution strength) and homebrew to calculate the alcohol content. What are you using it for in a MH?
  8. Warmleys
    Jul 15, 2015
    5
    Bournemouth
    thanks so much for your replys
  9. Warmleys
    Jul 15, 2015
    5
    Bournemouth
    actually, maybe it isn't a hydrometer as in brewing etc, its an LCD little rectangle,ar box with the temperature on as well
  10. NickNic
    Jan 14, 2014
    5,591
    11,491
    Kettering
    I doubt it's anything to do with liquid or moisture at all then. Maybe a picture of it would help.
  11. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    428
    Worcester
    Then it will be a hygrometer. All it is telling you is the moisture content in the air. With the weather at the moment it could well be 65% RH.
    • Like Like x 1
  12. Warmleys
    Jul 15, 2015
    5
    Bournemouth
  13. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,514
    1,637
    Stretford
    Hydrometer, What you doing growing skunk in your Motorhome, not a good idea(y)
  14. NickNic
    Jan 14, 2014
    5,591
    11,491
    Kettering
    He might be called Saul. We could all be calling him soon.
    • Like Like x 1
  15. TUCANO
    TUCANO Funster
    Aug 15, 2014
    870
    739
    Exiled in Yorkshire
    Thought you said he was maybe called Saul, so why you wanna call him Soon :whistle2:
  16. Warmleys
    Jul 15, 2015
    5
    Bournemouth
    So what is the name of the instrument that measures moisture in the air?
  17. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,698
    11,851
    Plympton, Devon
    A hygrometer. I think it be worth finding out, assuming you have a hygrometer fitted, where the sensor is. It could be measuring the humidity in the vehicle or someone has fitted a mini-weather station and it is sensing the outside humidity (RH). Either way I am not sure there is anything to worry about. It is damp inside the walls which is the killer.
  18. laird of Dunstan
    laird of Dunstan Funster Life Member
    Feb 15, 2015
    1,202
    3,219
    lincolnshire
    Moisture in the air is measured by "relative humidity" I've always called them rh meters , it will change depending on temperature as warmer air has a higher moisture content. A high reading would indivate that you are close to what is termed "dew point " that's where you see moisture forming on surfaces.
    you can lower the reading by using a dehumidifier,
  19. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
  20. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    428
    Worcester
    Neither is any use for measuring damp in a MH. The RH inside the MH will be the same as the RH outside unless you have heating or aircon on.
    • Like Like x 1
