3 in Trafic SWB low roof (1 Viewer)
Janners
5
Plymouth
Trafic
25 years
Going nuts! Somebody must have done a standard van conversion for 3. I have a van but campsites are getting to not like vans that aren't campers...or is it me?
So looking to convert the van to a camper (V5, insurance etc) but finding inspiration has got me stumped. I might be looking in the wrong places on the web.
Any pointers to send me off in the right direction would be most welcome.
Janners
DBK
18,009
48,001
Plympton, Devon
PVC, Murvi Morocco
There are folk who have converted their own vans on here, @Terry has done several I think and @Gromett converted his. There is also a different forum for self builders which has has a sort of link with this one:
scotjimland
2,246
9,759
A Woosh bang
It's not you.. most campsites do not accept unconverted panel vans.. or sign written vans.. that has always been the case...
Many years ago, I applied to join the Caravan Club when I had a self built Renault Traffic High roof, they wanted photos to prove it had been converted properly.. I think they have dropped that requirement
Not suggesting you should join the CC .. it's just a guide.. they still ask the same questions about a self built camper.. https://www.caravanclub.co.uk/CaravanClubApps/Applications/JoinOnline/joinasmember.aspx
Does the accommodation space contain the following equipment:-
  • Seats and table
  • Sleeping accommodation which can be converted into seats
  • Cooking facilities with adequate ventilation
  • Storage facilities
Yes
All the above must be rigidly fixed to the living compartment, but the table maybe designed to be easily removed.
From The Gov. DVLA pdf
In order for a converted vehicle to qualify as a motor caravan it must have certain minimum features, as follows:
  •  a door that provides access to the living accommodation
  •  a bed, which has a minimum length of 1800mm or 6 feet. This can be converted from seats used
    for other purposes during the day but must be permanently fixed within the body of the vehicle
  •  a water storage tank or container on, or in, the vehicle
  •  a seating and dining area, permanently attached to the vehicle. The table may be detachable but
    must have some permanent means of attachment to the vehicle. It is not good enough to have a
    loose table
  •  a permanently fixed means of storage, a cupboard, locker or wardrobe
  •  a permanently fixed cooking facility within the vehicle, powered by gas or electricity
  •  at least one window on the side of the accommodation
    If the vehicle has all of these features present, permanently fixed and installed properly, then it is a legal requirement to have it reclassified as a motor caravan on the V5C.
J
Janners
5
Plymouth
Trafic
25 years
The complying with VOSA.. no problem... AND fitting 3 is the challenge. I can see lot's of cardboard boxes being used to make mock ups.
But all good fun in the process.
I shall pop over and have a look at the other forum.
Janners
43,295
49,268
Along with Scotjimlands specifications, DVSA now want the outside to look like a motor caravan.
Proper graphics, a T.V. aerial/sat dish, a fixed awning/canopy or bicycle rack would do the job.
If accepted, the V5 will say MOTORCARAVAN under the body type section.
ANYTHING else is NOT a motorhome.
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Hi Just back from Southport so late replying Yes as @scotjimland says but I have now found out that when you have the MOT done on a van the tester can change category for you on MOT ie to Motor caravan -perhaps @Geo could confirm this ?We have just finished a Vauxhall Vivaro day van so you can look at the pics for ideas
http://www.motorhomefun.co.uk/forum...-vivaro-sportive-day-van.132197/#post-1894452
terry
