3.5 ton... ?
Discussion in 'Motorhome Chat' started by old-mo, Jul 7, 2013.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,992
    40,249
    Is there such a thing as a 3.5 ton Euro-van with a fixed bed and at least a desent single bed that is OK weight wise to tow a 1 ton car.. ?
    If so (which I doubt) what is the make and model.. ?
    Needs to be new or nearly new..
    And when you are restricted, because of your license,,, does that 3.5 ton have to include a tow vehicle... which would be on a dreaded "A" frame..
    Thanks..
  2. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    I would think there are quite a few out there to fit the bill.
    We have a Escape 644 (french bed) + a double , which is really a single. we tow a Fiat panda 1000kg loaded. (GTW 5500kg) no problem at all .The 644 also has a generous weight load , just weighed ours fully loaded, water gas fuel wife ! and still 180 kg available for wine !
    At the end of the day suppose it depends on the available budget.:thumb:
  3. old-mo
    Oct 16, 2008
    12,992
    40,249
    Bit confused...
    You quote (GTW 5500KG) isn`t that five and a half ton.. ?
    Not good with numbers is me.. :Sad:
  4. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,679
    14,537
    North Lincolnshire
    5.5 tonnes Mo, tons are finished.
    We are all metricified now.
  5. old-mo
    Oct 16, 2008
    12,992
    40,249
    What is the difference between 5.5 tonnes and 5.5 tons then.. ?
    Other than an "E" and an extra "N"... :Sad:
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,457
    7,555
    Nr Watton in Norfolk
    Here you go Mo -
    5.5 tons = 4989.52 Kilograms (approx)
    5.5 tonnes = 5500 Kilograms
    • Like it Like it x 1
  7. Steve
    Steve Funster Life Member
    May 8, 2013
    1,601
    1,903
    Compton Berkshire
    one old ton is 2240lbs = 1ton
    one new tonne is 2200lbs= 1tonne = 1000kg
    so an old ton is 40lbs heavier than a new ton. good old eu ripped us off. again.
  8. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,532
    2,652
    UK / Spain
    Hi Mo, you will keep your B and B+E providing you can still pass the eyesight test. :Eek!:
    See Here:
    On reaching the age of 70, drivers will retain their driving entitlement for Category B and Category B+E (provided Category B+E was held prior to the expiry date of their driving licence). Category B+E entitles drivers to drive a motor vehicle (ie car, van or 4x4) not exceeding 3.5 tonnes Maximum Authorised Mass* (MAM), drawing/towing any weight trailer/caravan within the prescribed maximum towing weight. The maximum towing weight will be specified in the technical data section of the vehicle manufacturer’s handbook. However, Club recommendations on weight ratio between trailer and towing vehicle remain at 85%. *The terms ‘Maximum Authorised Mass’, ‘Gross Weight’ and ‘Permissible Maximum Weight’ all have the same meaning, ie the weight of the vehicle plus the maximum load the vehicle may safely carry. When drivers of any vehicle over a MAM of 3,500kg reach 70 years of age and their driving licence expires they must pass the D4 Medical Test and pass the required standard eyesight test at 20.5 metres/67 feet with glasses used when driving. This legislation became effective from 1 January 1998.
    :Smile: Bob.
    Whats next another fifth wheel or caravan. :Doh:
  9. keith
    keith Funster
    Aug 25, 2007
    3,288
    1,674
    Ecclefechan
    Car not included in the 3,500kg but you need to check the gross train weight (Van & trailer). My GTW is 6000kg so ample for a car.
    Ours is an Autocruise Starseeker (07) that fits the bill, but don't know if they still make that model.
    So they are out there, just have to keep looking.
  10. old-mo
    Oct 16, 2008
    12,992
    40,249
    Cheers Bob.............. It`s the 70th birthday looming..
    And keeping my C1E with 107 entitlement that has bought about the question...
    If I fail my medical, just weighing up what I could get and tow a car, with the 3.5 ton (Tonnes) max..
    Not a lot by the looks of things... :Sad:
  11. vwalan
    vwalan Funster
    Sep 23, 2008
    7,677
    3,953
    roche cornwall
    mo. on a b+e its possible to have a train weight of 11-12 ton with the right set up .
    fifth wheeler is the way .but getting the right tow unit is the important part. the only weight limit is the train weight allowed of the tow unit . no 8.250kg limit as in the c1+e.
    • Like it Like it x 2
  12. Spottycatz
    Spottycatz Read Only Funster
    Feb 17, 2013
    452
    486
    Racodorm
    The plate inside the bonnet says our MH is 3.5 ton and can go to 5.5 if towing!
    Have a look at the photo's I've put in the album. It might be the type of vehicle you want to look at. :thumb:
  13. G8WVW
    G8WVW Read Only Funster
    Jan 15, 2013
    92
    66
    Cumbria
    Just be careful with this as my Sprinter has something similar however as the chassis has been extended there is a derating table in the handbook because of the extra overhang. The chassis plate was fitted in the Merc factory before the vehicle was converted.
    Cheers.
