2nd battery (1 Viewer)
SteveG
79
54
NW England
Newbie
been quoted £200 to fit a 2nd 110ah battery to our MH. Anyone got any thoughts?
Badknee
7,407
412,709
notloB
Vantage Neo
Living the dream.
Quick look on flebey showes them from £60.00 to £90.00 so charging say £120.00 to fit it. Seems a bit steep but I don't know the fitting details, how far apart are they etc.
SteveG
SteveG
79
54
NW England
Newbie
I thought it was a bit steep as there should be minimal wiring, the 2nd one should fit under the locker right behind the battery box
tonka
10,830
21,527
Cannock, Staffs
A class Burstner 800
Since 2000
A lot of vans have the wiring already in place for a second battery. Autotrail for example just need a wireing harness thats £20 from Sargent....
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Banner 110Ah battery £109,battery box £25 from reputable dealers-not ebay.
If anyone doing work for me said they would buy off ebay-I wouldn't use them.
I would probably have 2 new batteries-not add 1 new one to existing battery (unless it was a new one)
7,512
19,937
Lanzarote
Nil by mouth
Lots
Battery £79 ( I have 2 of these)
Broken Link Removed
Cables £11
Broken Link Removed
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Hi tonka my vans the same as yours have you more information on the harness as when I get back I am going to fit a second battery, also were have you fitted yours?
Laurie.
3,423
12,223
South Staffs
Pilote P740GJ
Since 2013
It does seem a lot of money. Fitted an extra battery to mine the weekend but they are next to each other so I didn't need much cable. Don't know if it makes much difference but I was told to take the positive feed off one battery and the negative feed off the other.
tonka
10,830
21,527
Cannock, Staffs
Since 2000
Laurie.
http://sargentshop.co.uk/epages/eshop328964.sf/en_GB/?ObjectPath=/Shops/eshop328964/Products/WB1022
If you look where your current battery is now, you will find a "socket" already attached on the cable. Most likely it will have a blanking plug inside to prevent any shorting, you take out when you connect this harness.
REMEMBER..... When fitting second battery you must fit the breather pipe and make sure it goes out under the van floor...
Also ensure it's fastened down. Autotrail gave me a "bag" that mine sits in but you can also use a battery box, this is in case of acid leaks... My second battery is fitted above the first under the dinette seat..
http://shop.lodgefarmleisure.com/thetford-battery-bag-553-p.asp
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Thanks for you quick reply tonka, will get on on order for when I get back.
it will make a neat job using the plug in harness, rather than me cobling something together the price of bits would work out about the same.
