240 volt 12 volt TV power question
Discussion in 'TV & Satellite' started by Road Runner, May 8, 2009.
  1. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Is a LCD 12 volt TV run direct from the battery going to use much less power than an ordinary TV though an inventor.
    I am guessing YES!
  2. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    eeerrr Yes
    The invertor is a much less efficient system and uses a lot of power even if nothing is plugged into the 240 v side
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    yes more economical because the inverter is not 100% efficient (anywhere between 70 and 95% actually). Therefore using up to 30% unnecessary power.
    Or to put it another way the inverse ratio of the spondulicator is proportional to the square root of the pelgum bracket multiplied by reflective and reactive component of defractulator, unless the square of the capacitive inductance to modified thromb pin is greater than the inbuilt losses known as the GT factor.
    :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  4. dazzer
    Jul 30, 2007
    1,698
    99
    In my house
    Guess i got it wrong
    I thought it was all to do with the sprangle flange have a negative influx on the ohms driven dooburry :thumb: :Rofl1:
  5. June and Mike
    June and Mike Read Only Funster
    Mar 1, 2009
    75
    11
    In the beautiful fens
    have u been googling wildman:Laughing:
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    agreed Roger.....but the new breed of 12v tv's have a clakvalve in series with the capacitive inducer.....if its connected by the anode AND cathode to a 0v supply it cancels the GT effect and with the moded thromb pin works much more efficiently so a 12v 110ah battery will last, on average, 12 years without recharge.
  7. Shubberdog
    Shubberdog Deleted User
    Be careful an LCD TV requires 12volts you very rarely get 12v. from a battery. Damage can occur over a period of time. :cry: I would sugest using a 12v./12v.regulated output power supply they can be found on ebay for about £40 :BigGrin:
  8. mulaz
    mulaz Read Only Funster
    Apr 14, 2009
    97
    3
    Durham
    12v tv
    Why over a period of time???????:Confused:
  9. 45eEver
    45eEver Read Only Funster
    Apr 15, 2009
    267
    If your tele also runs off 12v, it's probably got it's own inverter Road Runner.
    I doubt if the difference is worth bothering with in terms of electricity used.
    From my point of view, ferkling about with one gadget instead of two makes more sense.
    If you are charging torch or toy batteries, 12v is the better option electrically and ferkling aboutly.
  10. andyman
    andyman Funster
    Sep 23, 2007
    1,142
    494
    Leicestershire
    I bought a UMC Tv from Makro, it is the same as a few traders sell at the shows. They normally sell at the shows for around £200. Makro £130 inc VAT it is only 2.3 amps. It has a mains unit that drops the voltage to 12v dc. I use the mains when on hook up but other wise it is plugged into the cig lighter without a voltage stabiliser and so far no problems.
  11. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    A large number of domestic products reduce the 240V A/C to 12V DC, so one with a 12V input just removes the reducing stage, however LCD screens are prone to problems unless the supply is regulated, maplin supply a suitable regulated DC/DC power supply.
  12. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    No need I went to college.
  13. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Sorry John cannot believe that you forgot to factor the internal losses of the battery.:thumb::thumb::thumb:
  14. mulaz
    Apr 14, 2009
    97
    3
    Durham
    12v reg
    Here's a question!
    I'm like lots of others run my TV directly from 12volts when not hooked up,
    Bush TV/DVD/FREEVIEW 240v-12v adapter £135
    Clearance Bargains - hundreds of bargains available every day! Argos returns etc worth a look
    is there any form of regulation from your mains / fused / control unit when your TV is plugged into the habitation 12v sockets.
    i can understand if you used crocodile clips straight to the back of the telly but as other 12v electronics are ran from your battery surely they are all regulated.
    my lunar motorhome manual is 6 pages of photo copied A4 for 7 year old . No technical data
    may Google the control unit
  15. Shubberdog
    Your TV is designed to work from its power supply ie.12v. The voltage from your battery will be about 12.8v this slight over voltage will not cause it to suddenly go bang but will over time degrade the LCDs (picture) until eventually it will be un-watchable. The problem is made worse if you are charging the battery at the same time i.e. running the engine or using solar panels as the voltage will be even higher :Doh:
  16. mulaz
    Apr 14, 2009
    97
    3
    Durham
    Just remembered that i fitted a diode well over a year ago to the 12v lead supplying power to my Pace sky box.
    The info can be found Product Information:BigGrin:
    i have used this cheap mod on my sky box with no problems
    will also do the 12v lead to my New Tv
  17. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Not quite sure what you think a diode does, in fact it prevents current passing in one direction, it will also drop voltage across it the amount depending on the type of diode.
  18. sinbad1
    sinbad1 Deleted User
    Wilman is quite correct diodes are not voltage regulators, if you wish to protect sensitive equipment whilst using battery as a supply.
    This is what you will need [ame="http://www.amazon.co.uk/Amperor-LCD-Volt-Stabiliser-Regulator/dp/B000ZLRXG8"]click here[/ame]
    Regards
  19. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    [​IMG] Oh well !!!!!! i guess i missed college that day...:BigGrin:
    [​IMG]
  20. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    I imagine that TVs sold for the leisure business are more likely to have regulators than those sold in supermarkets etc, which are mainly intended for household use.
