240 V socket
Discussion in 'Motorhome Chat' started by gordoncbrown, Jan 6, 2013.
  1. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    834
    568
    Scotland
    Hi, I am looking to put a 240v socket outside, the same type as the hook up cable. I remember seeing a kit that had everythin that was needed in it. All that you had to do was drill a hole in the wall and wire in to the back of an existing socket. I have tried several searches without any luck. Does anyone know where to get one or reccomend an alternative.
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    The information you need is probably on This Thread from a couple of months ago.
    AFAIK the regulations state that only a qualified electrician can wire in an outdoor socket permanently but it is OK to terminate the cable with a normal household plug and use an existing socket (best to use a plug in RCD though).
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
  4. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,621
    2,191
    Rutland
    Hi Gordon ,I did the very same thiny myself about a month ago.I bought an ip66 outdoor waterproof socket from eBay which I fixed on the outside wall of my house roughly in line with a socket on the wall inside .
    I then simply cut the plug and flex of an broken outdoor appliance,drilled a hole through the wall,leaving the plug next to the socket fed the cable through the hole, cut to size and wired into outdoor socket.When I want the outdoor socket to have power I simply insert the plug inside and flick the switch!No need to get into removing sockets and wiring in,and all fully legal. If done this way no need for an electrician.
    The inside socket eliminates the need for a plug in rcd as this should be covered back at the fuse box.I just went for a normal outside socket so as I could use it for other things,then made up a lead to go to van.Dont forget to vase sealant to seal hole
    Regards vlad
  5. StitchUp
    StitchUp Funster
    Mar 12, 2012
    884
    953
    Bridgend, South Wales
  6. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    oops miss read what you actually wanted.
    as an alternative to a permanent fixed socket and having to have an electrician fit it for you get one of those 13amp plug to the hook up socket and take the 13 plug off it drill the hole through your wall near the socket feed the cable through and refit the plug.
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,389
    5,416
    East Sussex 01-580-881288
  8. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,395
    11,783
    E Yorks
    Even when using an outdoor electric appliance (such as hedge trimmer) isn't it still recommended to use an RCD device in the socket? Or am I out of date.:Blush:
    As for installing an external socket, if you do this, make sure you have a way of securing your cable to stop it being nicked! We use an adapted hook-up cable with a standard 3-pin 'household' socket on one end with the lead fed outside the garage to the motorhome over the corner of the door frame which has a nice little gap, just right to let it through without squashing it, that way the only way that someone could nick it would be to cut it ... and electrocute themselves in the process hopefully!!!! :Rofl1:
    • Like it Like it x 1
  9. GJH
    Aug 20, 2007
    27,349
    34,968
    Certainly recommended with a cutting device and it definitely does no harm with anything else :BigGrin:
