2017 Ducato querie (1 Viewer)
Dec 18, 2011
745
507
Hull
Autotrail 634
Since 2006
When I turn my ignition on I get an oil level check with 5 bars which I'm hoping means the oil level is ok.I also get an annoying noise each time I turn it on or off.Is there anyway to disable this please?
Ksagic
110
46
Warrington
Burstner Elegance 890i
Hi, you are correct in regard to the oil level check, 5 bars is good.
Do you have the Comformatic gear box fitted? If so then the irritating buzzer is caused by the gear selector being in the wrong position when you turn on the ignition, if not then sorry can't offer any solutions as my moho is in storage and can't check.
Camper634
Dec 18, 2011
745
507
Hull
Autotrail 634
Since 2006
Thank you for the information.I think the annoying noise might be my dash cam powering up
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Have you noticed how it tells you when to change gear when you've got RANGE selected on the dashboard display? I'm trying to work out if that's helpful or creeping fascism. Assuming you've got a manual gearbox anyway.
Ours doesn't make any strange noises on ignition, so your dashcam theory may be spot on.
Lenny HB
52,685
147,599
On the coast in West Sussex
Hymer B678 DL
What I do like about the X290 with Comformatic is, instead of getting deafened by an annoying buzzer when you try to start it in gear it changes it's self into neutral - brilliant.
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Since 2004
Ours is just an irritating noise when switching off the engine. Nothing when starting.
