2015 Peugeot Boxer handbrake
Discussion in 'Motorhome Chat' started by Foghorn Leghorn, Jul 10, 2016.
  1. Foghorn Leghorn
    Foghorn Leghorn Funster
    Oct 26, 2014
    213
    150
    Dumfries and Galloway
    Help !!! After descending the Cold du Tourmalet my brakes got a bit hot with constant usage although I did try to limit my speed by keeping in a low gear .
    The problem is my handbrake won't hold unless were on the flat , foot brake is ok.
    Can it be easily adjusted or is it a visit to a Peugeot garage .
    It's an Ako chassis on the Bailey if that has any bearing on the handbrake setup
    TIA
  2. Jack Slipper
    Jack Slipper Funster
    Apr 9, 2016
    135
    68
    Lancashire
    Have the same issue with our 2015 model. It has to be fully up to hold which then limits the swivel seat travel. I'm going to call a local dealer, it should be a straight forward adjustment I think!
    • Like Like x 1
  3. campa cola
    campa cola Funster
    Oct 5, 2012
    2,873
    5,764
    Weegeland
    Same issue on my 2015 FIAT Ducato, so sounds like a problem ???
    • Like Like x 1
  4. SandraL
    SandraL Funster
    Jan 24, 2012
    265
    144
    Somerset
    Not sure if latest van is the same but x250 fiat / alko use fiat discs drum combination at the rear. Search x250 handbrake thread on forum. Handbrake adjustment starts at the drum, not with the cable. My vans holds well, 4300kg actual weight .
    • Useful Useful x 1
  5. Foghorn Leghorn
    Oct 26, 2014
    213
    150
    Thanks ever body for your replys so far looks like I'll have to find Peugeot dealer to sort this handbrake issue
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,118
    4,251
    Cotes d'armor, France
    The problem with descending steep passes like that is there you can't really keep off the brakes, the van is too heavy to be held back by engine braking. We came down from Col d'Aspin nearby a couple of months ago and I stopped 4 times to let the brakes cool down, we had discs all round.
    You might well have glazed the rear shoes with the heat, in which case, they will need to be changed, and the drums checked for overheating damage.
    • Like Like x 1
  7. Foghorn Leghorn
    Oct 26, 2014
    213
    150
    Hi Allan I have discs front and rear but the handbrake works of a small drum so I'm told so I'm hoping it's just out of adjustment although prior to my descent the handbrake seemed ok .
    When the brakes are cold the handbrake will still hold on moderate inclines but as soon as they get warm it starts to slip if on any sort of Hill.
    Hoping that the local Peugeot dealer here at Bagnere des Bigorre can help tomorrow as were following the TDF and don't want to be stuck here
  8. Foghorn Leghorn
    Oct 26, 2014
    213
    150
    Update !! Went to a Peugeot dealer in Bagnères-de-Bigorre and he was far from helpful after we were told by Red Pennant that they would look at the handbrake issue
    We then went into Tarbes and found a large Peugeot dealership who couldn't have been more helpful and bent over backwards to help us out .
    Result !! brakes adjusted , oil and screenwash topped up and €61 charge .
    Now parked up on nice aire with leccy hook up near city centre (y)(y)
    • Like Like x 2
