2013 Fiat Cambelt (1 Viewer)
MickyP
224
72
Alhama de Murcia, Spain
Sunlight Cliff 601
12 years plus
Can somebody tell me what the frequency is for changing cambelt on a 2013 Fiat 2.3 (130 Multijet) Miles/Kms Years
Thanks in advance
Feb 9, 2008
4,086
5,903
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I have a 2008 2.3 Ducato. I had the cambelt changed at 5 years which was at around 35,000 miles.
Didn't want to leave it any longer. I believe the recommended interval is 4 years but I am not sure.
Rgds
Bill
Al-Di
3,050
28,485
prestwich
Eura Mobil A Class
since 2013
4 yrs or 40.000 miles whichever is sooner, use a proper belt(gates) not cheapo, and change the idler pulley(adjuster)
Alan,
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Service schedule that I have for X250 2.3 says Check at 56 thousand miles and no mention of how many years. replace at 112
third from bottom
Techno
Jul 28, 2010
15,475
20,752
May 2010
Any Fiat garage should be able to give you a copy of an up to date service schedule. Have you had it serviced yet? and got a copy already
MikeD
3,936
3,697
London
IH PVC
Since 2012
I have read 150k or 7 years. But really it is not very clear.
Bit like Fiat oil change requirements :cautious:
Al-Di
3,050
28,485
prestwich
Eura Mobil A Class
since 2013
Sorry but dont do service books but do have 15yrs ex fiat experience, and stand by what I said,
PP Bear
7,735
28,162
Kent, UK
Auto Trail Dakota SE
It's ok having your fellow Funsters quote what we think, but it's your money, hence your risk. We get it wrong on our peril and then £1000's to repair :Eeek:
Had mine done at 6 years and 15K only. Gave me much peace of mind :)
OllieUK
259
300
Ramsgate
Bessacarr E520
Since 2009
I was told at a Fiat dealership change should be between 65 and 70000 kilometers or every 5 years. I already plan on having mine done next year 2009 model with 27000 on clock
Techno
Jul 28, 2010
15,475
20,752
May 2010
So the service schedule for the 250 I posted is wrong? a Fiat document.
Techno
Jul 28, 2010
15,475
20,752
May 2010
Quote from another web page
"Our initial batch of 2.3 X250 vans were indeed due for cambelts before they were 3 years old and the mileage limit was 180,000km which is 112,500 miles. I thought that this was stupid since the previous (2002 to 2006) 2.3 did not need doing before 156,250 miles and we had never seen any wear on those at that mileage either so I chose to 'roll the dice' and not do them until 180,000 to 200,000 miles.
I mostly got away with it but as these vans approached 185,000 to 190,000 we started having reports of starting problems and all of these turned out to be timing errors and upon removal of the belts we found teeth stripped! The lesson duly learned, and fortunately without any major expense we have decided that we would always do the change at 175,000 miles in future. The sample was of 10 vans and all were doing the same kind of work (driven hard, 5 days a week) and covered fairly similar mileages. 7 were changed between 180,000 and 200,000 without any problems and 3 had issues.
The answer to your question is that it is ALWAYS best to stick to the manufacturer's recommended interval, but realistically, the chances of anything going wrong with your vehicle within, say, 8 years or 150,000 miles is somewhat slim but I am not offering to pay to put things right for you if lady luck intervenes and you have a faulty tensioner of something!
Nick"
Techno
Jul 28, 2010
15,475
20,752
May 2010
I thought that you had the 3 litre, which is a chain not a belt, Andy............ Might explain it
No mate if you read it the right column is for 2.3 and 3 litre , then read the service item ! near the bottom
MickyP
MickyP
224
72
Sunlight Cliff 601
12 years plus
Thank you all for the replies lots of different answers here? When i asked the question I was awaiting delivery of the Van, now I have it and found the owners manual under the heading of Service Schedule and Replace Timing Belt it states the following: Replace at 180,000kms or every 4 years for particularly demanding use (cold climates, driving in the city, idling for long time, driving on dusty roads or covered with sand and / or salt ) or in any case every 5 years regardless of the Km covered.......
Quite a high milage then?
Techno
Jul 28, 2010
15,475
20,752
May 2010
YES (y) 112k miles
The guy I quoted you will see now runs his vans with confidence to 150k miles from experience
DuxDeluxe
14,628
72,247
Planet Zog
A woosh bang van
since 2008
I stand corrected! :blush:
Mileage is one thing but there is still common advice on the number of years for a cambelt which I always thought was 5. For the sake of the money, I wouldn't risk it, but suppose it is a calculated risk
Techno
Jul 28, 2010
15,475
20,752
May 2010
Yes agreed David 5yrs but some vans havn't even done 20k in that time.
When I had the 2.2 pre 2006 I took it for a new belt at 14k because it was 6yrs old. The mechanic looked at me like I was stupid but he did the job. The old belt was still like new so I then realised why. It is easy to be scared into work that you don't need on forums.
If that belt is good for 112k and fleets push it beyond 150k then swapping it at silly low mileage is a personal judgement call.
sean n maggie
672
327
leeds
autotrail
Guess i better check if ours is a belt or chain as almost 6 years old now.......only done 13000 miles but age will tell........
DuxDeluxe
14,628
72,247
Planet Zog
A woosh bang van
since 2008
Fair comment - a question of effective risk management(y)
Techno
Jul 28, 2010
15,475
20,752
May 2010
Yours is a chain Sean (y)
On the X250 the 2.2 and 3 litre are chain, only the 2.3 is belted
Badknee
7,395
409,031
notloB
Vantage Neo
Living the dream.
That service book is for a commercial vehicle not a motorhome. Your belt will be past it's best due to age not usage as will your tyres probably. If you have any doubt or worry get it changed, it makes sense.
Edit, so it's a chain so no worry.
Techno
Jul 28, 2010
15,475
20,752
May 2010
It could be two years old before is sells off the forecourt.
You could buy a new belt that has been on a shelf for how long?
Aug 30, 2012
4,270
11,303
Home of the war horse
burstnar T640
I did our fiat 2.3
belt and a full service before our moroc run at 40000 and 5 years old
Mainly to put my mind at ease before a long run
