2010 Autotrail Apache Dvd Player (1 Viewer)
Tresan
6
Hi all, I am a bit thick on electronic technology, the satellite set up is working perfectly with the drop down 15" LCD monitor at the front.
I have followed the instructions on the DVD, inserted a DVD into the Head unit this plays on the head unit (reversing camera) but not on the LCD screen.
The 12V is on and the entertainment switch on power unit is on. The manual says that it should automatically work, we do not use the DVD much but do like our music DVD's when away.
Is there any help out there?
Trevor and Susan
cazzarazza14
56
49
Stafford
Autotrail Apache 700SE
March 2015
I had trouble with the drop down monitor just check the connections in your electric cupboard push firmly in place worked for me
T
Tresan
6
Yes the TV monitor shows AV1 in the top right hand corner, the LCD TV works perfectly through the satellite, the Head Unit plays perfectly through the entertainment system for radio/cd and DVD but does not appear on the drop down LCD.
cazzarazza14
56
49
Stafford
March 2015
Might be best pop to an auto electrician could be a fuse or loose wire there not the best TV in the world to be honest I will look at mine tonight and see if there's any in line fuses for you I will let you know
T
Tresan
6
Thanks for that
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
Don't have ours any more but from memory I think from memory there is another change you need to make with the controller to select the DVD, other than the AV setting. Sorry I can't be more help.
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
I agree with Grumps. Firgot about this thread. I will check when I get home as we have the same one.
