2008 Ducato front suspension
Discussion in 'Tech/Mech General' started by iandsm, Jul 9, 2014.
  1. iandsm
    iandsm Funster
    Jan 3, 2008
    1,674
    2,829
    Suffolk
    Has anyone had to replace the front suspension strut on a 2008 Ducato with a Rapido A class body. At low speeds I can hear a groan from the front not a continuous sound, rather like something moving and releasing itself. this is only when I steer, left or right but it does not happen above say 5/6 MPH. Otherwise everything feels right and drives perfectly but there are two possible I think, either its the top suspension mount or its the plastic hose with the slit in which goes around the bottom of the Spring where it sits in the lower cup.
    It seems to me this is going to be expensive because the Garrage, who have yet to exam in the vehicle say if the strut has to be removed quite a lot of the dashboard Will have to come out. They say that was the case with a Hymer A class but to b honest the bottom of the dash in my Rapido looks just the same to me as a panel van.
    Any thoughts on the matter particularly from those who have had similar issues would be appreciated.
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,253
    33,169
    Lancaster
    Might just be a dry bush. Does it also do it when driving in the rain??
  3. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,611
    3,429
    Telford, Shropshire
    Sounds more like a power steering issue than a strut, does it do it when stationary if you turn the steering?
    D.
  4. iandsm
    iandsm Funster
    Jan 3, 2008
    1,674
    2,829
    Suffolk
    Thanks for your replies, yes it does it in the rain although we din't get much of that on our last trip, and also when stationary turning the steering left or right. I have given the bushes I can see a dose of WD40 without effect. when moving, unless crawling it doesn't do it all at all. I wonder if thats because there is less effort needed to steer when moving as opposed to stationary
  5. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,484
    888
    South Glos
    It will depend on whether you have any doors into the cab area. When I had the springs uprated on my Pilote the passenger side was easy because the door allowed easy access to the glove box area which had to be removed to get to the top of the strut mounting. The Drivers side however was not so easy as there was no door and the space was filled with lockers and a cover over the gas bottle compartment this had to be removed to enable access to the area behind the fuse panels to get to the top of the strut.
    If you have a 3ltr you may consider uprating the springs at the same time to improve ride and handling.
  6. iandsm
    iandsm Funster
    Jan 3, 2008
    1,674
    2,829
    Suffolk
    Thanks for that. Its the left side and the door is on the left being a French motorhome. Fingers crossed!
