2005 Ducato Radio Ariel
Discussion in 'Tech/Mech General' started by lunarman, Jul 22, 2011.
  1. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,472
    884
    South Glos
    I am thinking of changing the radio in the van so that we can play mp3 files when on the continent.
    One of the things I think I will need to do is change the ariel but I can't find where the existing one is. That is if it exists at all as we often lose the signal.
    Any suggestions where it may be and what I should replace it with.
    Lunarman
  2. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Well,ours is on the nearside front wing near windscreen-but I guess you'd have noticed that:BigGrin:
    Mike
  3. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I have a later 2009 fiat Ducato and the ariel I am told is is the passenger side mirror (RHD)
    Which is a lot more expensive to replace than the drivers mirror.
    Though its still rubbish reception mostly :)
    barry
  4. rangitira
    rangitira Funster
    Jun 30, 2010
    6,376
    13,163
    Cornwall
    Soon as you find out, tell us! as I have the same problem! Reception is crap and only works if the engine is running!
  5. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Fiat put them either on the roof or in the mirror, but the converter (lunar?) could put it somewhere else, so its very hard to say.
    I would recommend an external aerial, probably on LHS front wing.
  6. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Check your TV aerial booster - many of the Staus types have two outputs and a switch - one for tv one for radio. By running an aerial lead and adaptor from here to the vehicle stereo you can gain a much better/perfect reception - even if the aerial is not up or switched on. As long as it is attached, the aerial wil receive the signal - it's up on the roof anyway, so make use of it if you can!
  7. rob kinnear
    rob kinnear Read Only Funster
    Nov 29, 2010
    175
    31
    Swansea
    2002 ducato on right front wing the reception is still the same as all others c***
    Rob
  8. niggle
    niggle Banned - Rule 1
    Aug 5, 2010
    806
    607
    SOUTH AND FRANCE
    ive got what seems to be,, a stuck on one on the winscreen ,,it takes 12 volt from the radio its black plastic about 3 inches long and 1 wide ,,its great ,no probs with any station ???? i bought a ipod/mp3 tuner,just tune it into radio ,,i think 20 squid but a lot less hassel to work,,as any one will know if they have tryed to get the dash apart on a ducato to get to the radio :cry::cry:
  9. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,614
    22,772
    Narrfoook
    My van is a Miller ( SAE subsidiary ) .. All the buggers did was remove th eaerial and leave the wire !
    When I first got the van I fitted an on screen jobby.. but in all honesty it was far from great .
    I ended up going to Halfrauds and buying a standard roof mount one and mounted it on the side of the wing..
    About 300% better than it ever was ! :)
    Just a tip often forgotten when fitting a radio aerial
    Apart from the obvious work to be done ( as in drilling a hole and feeding the coax through ) do not forget to ensure the metal BEHIND the hole is cleaned off and bare.
    A car aerial works by using the actual vehicle as part of the system.
    If the mount has not got a good earth then the aerial will hardly work at all ( and be a magnet for all sorts of interference ! )
    Once you have fitted the aerial and all is tightened up, spray the inside with some primer of similar to seal it all back up again and prevent rusting ( just spray over everything, the area, and the inside of the aerial mount )
    • Like Like x 1
