2005 Autocruise stargazer reading light
Discussion in 'Motorhome Chat' started by Khizzie, Feb 19, 2015.
  1. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,916
    4,419
    Newbury , West Berkshire
    Hi has anyone e any idea how to remove the lens on these directional reading lights that are fitted above the benches?? I need to replace the bulb in one but for the life of me I cannot see how to get to the bulb to replace.cannot supply photo as have not means at moment to take a picture. Roy
  2. TERRY&PAULINE
    TERRY&PAULINE Funster
    Feb 18, 2015
    102
    100
    coventry
    ||Hi Khizzie we have a Starfire, think our lights are the same, there is a small slot on the rim I think you put a screwdriver in the slot and twist it off haven't tried it so be carefull
  3. Wickolad
    Wickolad Funster
    Sep 10, 2013
    482
    541
    Wickersley
    I agree with Terry, if they are same as mine, the tiny slot is at the base of the deepest point on the swivelling casing. Be careful to put screwdriver in slot between the base plate and the swivel cover, a simple twist and gentle lever will release the cover and lens. Simply change the G4 lamp, these 12v 15watt halogens can be replaced by G4 type LED lamps that use a fraction of the power.
  4. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,916
    4,419
    Thanks guys ,will give it a go later today, and thanks for the tip about replacing the bulb with a led...:notworthy2:
