Jim
Ringleader
Make a two stroke one Chris, it'll still be quieter than a Kipoor
pics of my unit.
it does brian:thumb:all to do with the gearingSo you've fastened 50cc a lawn mower engine to standard 70A alternator.
Got to admit, as a battery charger the theory is good. Only doubt is if the little motor can crank it at that 70A, probably will.
and how many amps does that push out 1 amp if lucky on a screeming 2 stroke,its not the same might be 12v but not the same.not even similar.
capable of I would guess 30A, although so far only tried it on slightly discharged batteries and got 15A.
if i straped a big v8 to it it still would be quieter than a kiporMake a two stroke one Chris, it'll still be quieter than a Kipoor
your correct it's not similar .. it is a lot lighter and>>>> I quote
not bad for a little strimmer ... even if it is noisy
and im taking it to the weston show as my only sorce of charging batteries,to give it a full test over four days,i would say it will only need to run for about an hour a day?????
