2000 Autotrail 634U fusebox location
Discussion in 'Motorhome Chat' started by gibbon, Mar 16, 2013.
  1. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    Hi funsters,
    We have recently acquired our lovely 2000 Cheyenne & of course I've been all over it trying to familiarize myself with every system to ensure it all works.
    HOWEVER, I can't find the habitation fuse box !
    I have asked the previous owner of 12 years but he always paid someone to do all maintenance so not really a "hands on" person.
    The only place I have yet to look is under the rear flap where the spare wheel & the battery lives. It's parked on soggy grass & it's been p#@*ing it down for days so I have'nt got around to crawling underneath yet.
    Seems daft to have the battery etc slung under the veh in the elements!
    Any advice would be greatly appreciated :thumb:
    Thanks in anticipation, Bob.
  2. billy
    billy Read Only Funster
    Jan 10, 2009
    658
    314
    Bolton
    Hello hello hello:Blush:
    Have you looked under the bench seats in the lounge area?
    Also have you looked under the bonnet I am not sure but I think I have heard mentioned on here before.
    billy
  3. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    Cheyenne fuse box location
    Hi Billy,
    Yes, looked at all accessible areas inside the van & under the bonnet.
    Our last van, a 22 year old Hymer had the fuse box,leisure battery & charger all together under the front passenger seat. Simples :BigGrin:.
    I assumed a more modern van such as Autotrail would have a similar logical electrical layout but in fact its all over the place!
    e.g. Control panel is over the habitation door.(checked behind panel,no fuses)
    Zig charger is under seat in U shaped lounge next to the 240v input/trip box. No sign of a fuse box.
    As I said in my first post, I've run out of places to look inside the van so hopefully when the weather permits I can have a good root around underneath where the leisure battery & spare tyre is stored.
    Thanks for your input Billy,keep it coming funsters, someone out there must have the same van as me:BigGrin:
    Regards,Bob.
  4. autoswan
    autoswan Funster
    Apr 3, 2012
    653
    1,540
    Swansea
    Hi Gibbon i have a 2004 autotrail cheyenne control panel above hab door & charger opposite in wall cupboard, the charger has a row of fuses built in at the front of it. I havnt seen any others elsewhere ! dont know if it helps you ?
  5. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    2000 Auto-Trail Habitation Fuse Box
    Have you looked under the wardrobe area on the left hand side. The current model 634u is there.
  6. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    Autotrail Cheyenne Hab fuse box location
    Mmmmm food for thought , the zig charger is a rectangular metal box with ventilation grills in it with visible circuitry & what looks like a copper coil.Certainly no sign of fuses on the outside,perhaps I have to take the metal casing off.I'll have another look at that.
    The wardrobe is next to the hab door,beneath that is a cupboard also accessible from outside.Nothing obvious.
    I'll be looking at that again,thanks all,and stand by for more daft questions:Smile:
    Bob.
  7. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    2000 Auto-trail Habitation fuse box/charging unit
    If you ring customer services at Auto-Trail and give them the reg and build number they will be able to tell you where the fuse box/charging unit is located. Area to check are the off side rear seating, upper locker and wardrobe area. It won't be in the spare wheel area as it will be to damp.
  8. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    Thanks Rolandrat , now I know what I'll be doing tomorrow morning :thumb:
    Regards,Bob.
  9. FM02MZO
    FM02MZO Funster
    Jun 22, 2012
    155
    28
    Castle Donington
    The locker that contains the charger unit has got a false floor, lift that up and all will be revealed. That's where it is in our Autotrail Mohican.
  10. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    I have had to admit defeat on this one, so I've just phoned Autotrail customer support.
    Guess what?
    My model does'nt have a habitation fusebox :Eeek:.
    Apparently the four little red switches on the left side of the control panel above the door are re-set switches (like breakers I suppose)
    No wonder I could'nt find it!!!
    Thanks for your suggestions anyway:thumb:
    Bob.
