2 Stroke Oil mixed with Diesel anyone tried it
Discussion in 'Motorhome Chat' started by Braunston, Apr 20, 2009.
  1. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
    Hi,
    Just reading on another forum a discussion regarding the use of a small amount of 2 stroke oil mixed with diesel, apprantly there could be a number of benefits, anyone tried it, does it work. There are a number of links if you google the topic here's just one of them
    Freel2.com - View topic - 2-stroke oil and diesel
    Be interested in your opinions
    Braunston
  2. zaskar
    zaskar Funster
    Sep 25, 2007
    989
    98
    UK
    Hmmmmm, the theory is fair, tho' TBH, my knowldege on this subject isn't sufficient to give you a DEFINATE answer one way or the other.:Doh:
    What I will say is this.
    At the moment, I'm looking for a Nissan Navara (long story which I wont BORE you with!:BigGrin:) On reading the Navara UK Forum, it would appear that the DPF (Diesel Particulate Filter) can cause problems by getting too clogged up. I don't know if the new Fiat etc engines are fitted with such a device, but I would have thought it worth checking because 2 stroke oil isn't the cleanest stuff to burn.:Blush:
    HTH
  3. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    WOW,,,,could be a winner !!!
    That looks quite interesting, where on earth did you dig that one up from ? when some replies come in I might try it it on my old diesel Rover banger !!!! :thumb:
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    OK, I've had a look at the site and I'm not too sure about the sulfa lubricating the pump and injectors but it could be true.
    I'm pretty certain that it wont do any harm, maybe the oil companies put it in and sell it at a marked up price?
    Maybe a drop of cooking oil will doo the same thing at half the price:Wink:
    Doug...
  5. Braunston
    May 21, 2008
    1,415
    7
    Hi, Zaskar
    I don't know anything about the subject or if it works, but in one of the treads there is a suggestion that it will stop the clogging on the Particulate Filter this is an extract from the link I gave earlier
    In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clogg, and the "burn free" process of the DPF will be much less.
    I don't know if its true or not.
    Hi, Steve4Kay, it seems like I've to much spare time, but don't tell her in doors or she will find me something to do:Rofl1::Rofl1::Rofl1:
  6. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    Great read and I am seriously thinking about trying it. :thumb:
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,757
    YO11 2BD
    one thing is certain.....you wont get a speeding ticket.
    they wont see the rear plate for 2 stroke smoke...:Rofl1::Rofl1:
  8. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,973
    2,777
    Englishman in Mid Wales
    Anyone tried it yet????? would be interested in the results, I think Im going to put some in my old Xsara TD and see if it does the trick:Smile:
  9. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,365
    1,447
    Suffolk
    I am a member of the Diesel Ram forum in the States. This was a topic brought up some time ago and most consider it to be 'essential' to maintain lubrication in the injection pump. As far as I know most of the members do this without any problems whatsoever, including me. It didn't seem to affect the emissions test as my Dodge has passed with flying colours. I only put a small amount in (about an egg cup full to a tank - 100 litres approx.). There are proper diesel fuel additives available which I imagine would do the same job.
    Nigel
  10. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    hi Wizzer your Xsara TD will run on just about anything :) mine Xantia does (bosch pump mind)
    John
  11. peter t
    peter t Read Only Funster
    Feb 26, 2008
    155
    Sunny Croydon.
    Get yourself comfy and have a look through these threads.....
    Ford Transit Forum • View topic - two stroke oil in the diesel ?
  12. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,973
    2,777
    Thanks for the info guys
    I have found some of the required 2stroke oil today and added 270 ml to a full tank (54Litre) too soon to tell at the moment but will let you know what I think in due course.
    Sundowner interested that you use much less than the recommended??? (200/1) dose, why is that?
    Johng not sure what pump mine has but as its only a banger I thought it would be an interesting experiment not least cos it smokes (black) quite a bit on hard acceleration:Blush:
    Tim
  13. Sundowners
    Oct 30, 2007
    2,365
    1,447
    Suffolk
    Hi Tim
    I'm not following a recommended quantity, I just use the principle that it's extra lubrication and the pump doesn't rely on this alone, so anything is better than nothing. Time will tell.
    Nigel
  14. 45eEver
    45eEver Read Only Funster
    Apr 15, 2009
    267
    The man recommends .3 litres per 70 litres.
    That's 1 litre to 233 litres.
    Cost, nearly a tenner for a litre of half decent 2 stroke oil.
    A proprietary lubricator to treat 475 litres of diesel costs £23.
  15. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,973
    2,777
    Hi Nigel
    Mmm probly good thinking, Ill give it three or four tankfulls at the recommended?? dose and if I think its worthwhile then I think Ill do what you do or bring it down gradualy to see if there is any differance.:thumb:
    As you say the yanks seem to have been doing it for years so I guess there must be something to it.:Blush:
