2 stroke oil in the diesel broke the windscreen wipers.
Discussion in 'Motorhome Chat' started by Simon, Apr 7, 2015.
  1. Simon
    Simon Read Only Funster
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    So, I happened to read somewhere on here that many people put 2-stroke oil in their diesel at a tiny ratio of 1:200. Reading up on this from various reputable-ish sources I found it's suggested that this can be beneficial, especially to the older type engine that can run quite happily on beef dripping sandwiches, and has been done for years. It certainly wouldn't do any harm anyway, so I considered it worth a try.
    There was about 200ml in the bottle in the shed so into the half-full tank it went yesterday.
    I'd planned on filling the ol' bus up to the brim anyway to pre-empt the inevitable massive price rise before we go off gallivanting in May, and I thought this activity would also give the 2 stroke oil a good mixing-in, so off we went today to do that very thing. On the way I noticed the windscreen had got quite dusty so I gave the wiper stick a flourish. Nothing. I pulled it toward me for the squirters to squirt. Not a drop. Bugger.
    Checked the fuse box - the wiper fuse also protects the windscreen washer pump, the temperature gauge, the interior heater fan, and other stuff, most of which still worked.
    I had recently taken out the radio to install some new speakers so maybe something had been disturbed in the massive bundles of wires behind the interior plastic bits? Lots of quite painful upside-down-under-the-dashboard testing proved that no, it was all fine. Must be the 2-stroke oil then! I've cursed the electrics by feeding the engine stuff it wasn't expecting! Like many children these days it's a fussy eater and is going to cause havoc until it gets exactly what it wants! 2-stroke oil is obviously the Brussels sprout of the Fiat engine world.
    Or... more realistically, maybe it's the wiper motor? Or a dodgy earth? Or something? All the spiky little bundles of earth wires I could find were checked but they seemed ok. I even took out the speedo/gauge module and unplugged everything in there, then plugged it all in again as I read that this is another weird thing Fiats like to happen quite regularly or random things stop working.
    Finding the wires attached to the wiper motor was a challenge as they're hidden behind metal things, but undoing a few little bolts had the thing out. I unplugged the motor and plugged it back in again a few times, went inside and wobbled the switch. Mrs Simon reported movement so I put it all back together again and it works fine! Did the same with the washer pump connection and that now works fine too.
    It seems Italian electrical connections like to be taken apart and put back together occasionally. They must get bored and crave attention. If only there wasn't so many of them.
    Fiat - fix it again tomorrow! At least it was sunny and warm, which makes a change when things like this happen.
    • Like it Like it x 9
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,265
    17,931
    YO11 2BD
    Should have put a little 2 stroke oil on the connection plugs and sockets for lubrication purposes.
    • Like it Like it x 3
  3. Popeye
    Popeye Funster
    Sep 5, 2011
    8,004
    18,354
    New Forest
    They need you at the fix it meets.........:wink:
    • Like it Like it x 2
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    Nice story, made me chuckle on a non-chuckling day. Thank you.
    But I would dilute the oil to something like 1:1000, it will be cheaper and you and the engine will benefit. :):)
    • Like it Like it x 1
  5. ianhyslop
    ianhyslop Funster
    Jan 20, 2015
    175
    167
    Fife
    I think you have been drinking the oil .
  6. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    *Long silent pause for thought*
    Good idea or not, if you think I'm taking all that lot apart again you've got another think coming!
  7. pappajohn
    Aug 26, 2007
    30,265
    17,931
    YO11 2BD
    But if it packed in again you could definately blame the oil.
  8. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,347
    1,701
    Dover
    I had two stroke oil problem causing light total failure with a Lambretta SX200. The problem was it wasn't good enough to keep the engine from seizing solid at 60 mph on a very dark road. NO LIGHT AND LOCKED REAR WHEEL, make for increased heart rate, luckily when I let out the clutch is ran again normally. So 2 stroke oil does cause electrics failures.
  9. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,975
    14,094
    Norfolk
    Thought for a minute you had put the 2stroke oil in the washer bottle :rofl:
  10. Silver-Fox
    Silver-Fox Funster
    Sep 5, 2014
    1,026
    1,599
    Cheltenham Spa
    Try owning a Ducats bike then with their elactrics:)
  11. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    I've heard all about them! I suspect, however, that a Ducati's loom is somewhat smaller than a DucatO's and more readily accessible too.
  12. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,643
    5,706
    Yr Wyddgrug
    It's all OK now then .... that was a stroke of luck.:cautious:
    I'll get my coat :getmecoat:
  13. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    I was trained as a (proper*) mechanic many years ago so that was unlikely, but I bet things like that have happened many times before.
    * A mechanic who diagnoses and repairs, rather than just swaps circuit boards until the car works again.
  14. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,347
    1,701
    Dover
    I thought they put it through the frame tubes on Ducati but I am probably thinking of something really expensive.
  15. Allanm
    Allanm Funster
    Jun 30, 2013
    3,261
    4,435
    Cotes d'armor, France
    Simon fixed the wipers and the washers,
    so that's 2 strokes of luck...
    :getmecoat::getmecoat:
    Allan
  16. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,921
    23,681
    Narrfoook
    I think that is almost an oxymoron !! Using the word 'loom' and 'Ducati' in the same sentence !!
  17. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    Heh! "Bundle of old wires that were salvaged from house rewires" then?
  18. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Does it have to be 2-stroke oil or can I use some of the left-over bits from when I had a diesel car?
  19. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,086
    3,482
    Eastbourne East Sussex
    I understand that it must be mineral 2 stroke oil, not semi or synthetic as that doesn't mix well with the diesel. So its the cheap stuff you want, I use Tesco own brand when they have it.
  20. John Laidler
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    I think it was Buell who used the frame as an oil tank. Now no more though the founder has started making bikes again I believe, having sold his brand to Harley Davidson - who killed it off.
