I seem to remember in my teens the trend was adding castor oil to your two stroke so it smelled like you were running Castrol R racing oil
Okay I vote to guinea pig it.
For every negative thread there is a positive,
Remember that these engines are used all over the world not just in ultra green Europe. The quality of fuel between here and France varies so what must the difference between here and Africa be
Castrol R what a evocative smell, proper race bike smellI seem to remember in my teens the trend was adding castor oil to your two stroke so it smelled like you were running Castrol R racing oil
I was not saying that the oil will bend the con rods but if the timing is too advanced because of it, it becomes a possibility. You obviously understand the ratios of mixtures but some people have a tendency to add a bit more to get more and then things go wrong.As I said I tried it & don't bother now. But to say your con rods are going to bend is a bit dramatic, 300ml to 80lts of fuel is not going to bend con rods. Friends of ours got a lad that hoones a old pug 205 around the fields running only on waste oil from our local garage & nothing else, bugger to start when its cold & smokes!! Its the injector side of things that is quieter
As well as the fuel quality being different around the world, some manufacturers do fit different spec engines for the market they are sold in. BMW and Landrover to name a couple and the differences even includes the metal that the liners are made of.Okay I vote to guinea pig it.
Yes, and the infamous Nikasil liners that Jaguar and BMW used in the 1990's are testament to getting it wrong. Higher sulphur levels simply destroyed them........ (Says he looking for an XJ8 for Rust2Rome......)As well as the fuel quality being different around the world, some manufacturers do fit different spec engines for the market they are sold in. BMW and Landrover to name a couple and the differences even includes the metal that the liners are made of.
True, but just to clarify.... The palm oil needs to be treated before it becomes a biodiesel component, known in the industry as RME. Current EU regs call for 5% bio product in the diesel oil, which is actually a good thing as it is a decent lubricant for the engine, effectively replacing the sulphur which previously lubricated, or indeed expensive lubricity improver. No worries about lubrication from European fuels - it all has to pass the lubricity test using the HFRR (basically a vibrating rig - measure the wear scars after a certain time)I would not do it to a modern diesel engine ,I used to put vegetable oil into my diesel in an old 1995 shogun ,it smelled like a chip shop but ran with no problems ,the diesel that you buy at the pump has vegetable oil in it ,mainly palm oil ,hence the increase in deforestation in Asia ,when Mr van diesel originally conceived of his engine his intention was that it would free poor country's from having to use petroleum based products , the early diesels could run on just about any oil
Anyhow I would not put anything into the diesel , thinning it will cause excess wear to the engine
Hi John, it just occurred to me that if it is an upper cylinder lubricant then if 2T is anything like marine upper cylinder oil, it will be extremely alkaline which could have an adverse effect. Maybe not so much as marine engines (every marine diesel about about 3000 HP is a 2 stroke) burn fuel with a higher sulphur levelIn emergency situations I have stuck all sorts in my diesel tanks over the years.. from cooking oil to ... well you name it.
2T is merely an upper cylinder lubricant.. and at the ratio's quoted will almost certainly do little or no harm.
However.........
Some of the claimed figures can only be viewed askance .. And the cost of decent mineral oil 2T would mean an over all saving of very very little..
In the words of the dragons.. I'me out.
As a by the by, I noticed some garages in Germany are now ONLY selling unleaded with 10% Ethanol in it.. I would rather use chip fat in a diesel than Bio in a petrol engine.. Unless the thing is built to use E10 it can cause all manner of gumming up.. bloody stuff is a nightmare !
Plus it dissolves cork and certain rubbers and a propensity to suspend water so causing corrosion in float chambers and fuel pumps, if I could avoid using the stuff I would!!Whoever decided that ethanol should be added to vehicle fuel needs their bumps feeling. It is very aggressive towards fuel lines and paint used in lining fuel tanks, fetching the paint off in great lumps and turning it into something resembling wallpaper paste. And what's more it is more expensive to produce and is environmentally unsound.
