2.8jdt
Discussion in 'Tech/Mech General' started by LOOSE WHEEL, Apr 20, 2016.
  1. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    69
    67
    WORCESTER
    my 2.8 jdt if left for a fortnight .
    Turn ignition on wait for all lights to go out, when you crank it injector light flashes with each turn of engin, normally tacks 4-6 turns once it's started runs fine and if you use it every day or two no problems with starting.
    Only other thing it does is every now and then when it drops down to tick over it flutters a bit.
    Checked all push on fuel pipes and top of tank for leaks have not found any.
    Any ideas.
    Regards Andy
  2. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,262
    3,505
    Rural South West Wales.
    When was the fuel filter last changed ?
  3. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    69
    67
    WORCESTER
    Every year mate when I servies it I.v even taken it off again to check
    And put some fuel clearer through it. About three weeks ago and give it a good run.
  4. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,262
    3,505
    How's the starter battery voltage after standing for a fortnight ?
  5. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    69
    67
    WORCESTER
    Very good mate.
    It's like in old days if you had a slight air leek and used to get run back.
    But can.t find leek and don,t like messing with these later fuel systems.
    Give me a good old Tdi any day .
    Andy
