2.5mm orange cable.... Where to buy (1 Viewer)
dippingatoe
Jul 23, 2013
630
1,232
UK
Thor Damon Daybreak 27P
jan 2014
Where is the best place to buy top quality 2.5mm orange cabling for hook up purposes?
Many thanks
Silver-Fox
9,234
28,699
Cheltenham Spa
Rapido
im a not so newbie
Ebay is your friend
You will struggle to buy cheaper, I'm in the building trade and can't get it as cheap
dippingatoe
dippingatoe
Jul 23, 2013
630
1,232
UK
jan 2014
Sadly I have tried the local wholesalers, screw fix, eBay and amazon and so far drawn a blank :(
dippingatoe
dippingatoe
Jul 23, 2013
630
1,232
UK
jan 2014
Now - how come you lot could find all those. I tried and just came up with 1.5mm :(
Thanks all :)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Do you need 2.5mm?
Most sits are limited to 6A or 10A anyway.
Peter
Very few that we go on - most are 16amp best to have the maximum capability won't hurt going down to 10 amp or 6amp but get 1.5 sq and you will be in probs. on 16amp
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Given that my link is to a 25 metre 2.5 with plugs and delivery for only £28.50 why would anyone want 1.5mm? that does not meet BS 7671 and probably no cheaper.
it is very likely that the earth loop impedance of 1.5 over 25 metres is not low enough for a 16 amp protective device to operate fast enough
Oct 26, 2014
732
1,426
Lincolnshire
Adria Coral Supreme 680st
since 2001
Hi all,
is there any reason not to use say 2.5mm blue arctic cable? as I can get it for £44 for a 100m roll,
I have just been given enough fittings to make up 3 leads of varying lenghts plus a RCD protected hookup point to connect just outside the garage.
Andy
Techno
Jul 28, 2010
15,475
20,752
May 2010
No you won't. 1.5mm flex is rated at 16A.
I do accept the reasons for preferring 2.5mm though (y)
1.5 is rated at more than 16 amp but it does not meet earth loop impedance requirements at 25 metres long. See post above
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
You can buy the orange caravan cable in Wilco's .
Vlad
dippingatoe
dippingatoe
Jul 23, 2013
630
1,232
UK
jan 2014
Many thanks for all the replies - it was needed in a hurry and purchased at a higher price than I might have liked, but will be delivered tomorrow :)
ubuntu1
155
44
Derbyshire
PVC
since 2006
Nothing wrong with blue arctic cable. Its got 2.5mm conductors the same as the orange. The blue just stays flexible down to very low temperatures.
Techno
Jul 28, 2010
15,475
20,752
May 2010
Hi all,
Andy
Orange is recommended but the regs require BS7919 or equivalent (stamped on outer sheath)
I have been using blue all winter.
Lenny HB
52,684
147,589
On the coast in West Sussex
Hymer B678 DL
Some facts about why 2.5 mm sq cable was specified.
When the NCC & IEE drew the specification up for caravan hook up leads over 30 years ago the standard rating for 1.5 mm sq cable was 15 amps (higher purity copper was available with 16 a rating) the 2 pin & couplers were rated at 16 amps so the next standard size cable available was 2.5 mm sq rated at 20 amps.
I rarely use EHU when I do carry a lead. It's 1.5 mm, 2.5 is far too heavy and awkward to use. don't see what earth loop impedance has to do with it as you are protected by an RCD in the van.
It appears to be only the UK that has this standard, go into any continental accessory shop and the standard cable is usually a 50 m 1.5 mm sq black rubber sheathed cable.
Techno
Jul 28, 2010
15,475
20,752
May 2010
The RCD requires an earth to operate and the earth is as far away as the cable is long.
This is why you must use the test button on your device every time you hook up somewhere new, to prove the earth.
It probably pre dates vans having their own RCD.
I don't suppose the caravan club or any other organisation is concerned with your RCD that may or may not work correctly but for theirs to operate fast enough at 30ma leakage does require a lead as specified by BS 7671. No one checks until there is a claim.
Couple this with the INCREASED resistance of cable that is not fully uncoiled!
Emmit
8,006
17,534
Cornwall
Pilote Explorateur
Jan.2014
"It appears to be only the UK that has this standard, go into any continental accessory shop and the standard cable is usually a 50 m 1.5 mm sq black rubber sheathed cable."
That maybe so but in our Hobby Manual it specifically says that 25Mts should be the Maximum length of EHU.
Regards
Lenny HB
52,684
147,589
Hymer B678 DL
No it doesn't RCD is a residual current device with detects an imbalance of current between live and neutral. If the current out flowing around the circuit does not equal the return current it will trip, i.e. You grab a live wire and some current will flow through you to earth so the return current will be less than the outgoing current so the RCD will trip.
The RCD is only connected on the live & neutral lines there is no connection to earth. The trip switch on the RCD just connects some resistors in circuit internally in the device to give a current imbalance to test the action of the RCD and serves no other purpose, it is a crude test and does not guaranty the RCD is fully functional.
Techno
Jul 28, 2010
15,475
20,752
May 2010
The RCD is to complement electrical safety and not to be used as a substitute for a correctly maintained earth.
I have to concede that the RCD device does not require an earth to operate
