Rob and Val
- Oct 17, 2010
- 1,906
- 2,677
- Talbot Compass Calypso
- Since July 2010
More than 2.5 million motorists failed their MOT tests in 2016, according to confused.com, because their vehicle had a bald or defective tyre.
Unless a lot of touring miles are covered it is unlikely that your motorhome tyres will wear out. However, like all tyres, they will deteriorate with age and can become distorted if they are left unused in the same position. Motorhome tyres that are on a stationary vehicle are always likely to age more quickly than those in regular and frequent use.
So, check the condition of your tyres as well as the air pressure in your tyres. In particular, check the tyre walls - exterior and interior. Surface cracking of the sidewalls can occur if the motorhome tyres are allowed to become under-inflated and remain for a long period of time in that condition. This means that the tyre could burst when you are driving.
You can identify the age of your tyres by the date code printed on the tyre sidewall. Basically, a three digit code means the tyre was made before 1999, which was replaced by a four digit code in 2000. After 2000, the code stands for the week and the year in which the tyre was made, i.e. 0310 would mean the tyre was made in the third week of 2010.
Leisure vehicle organisations recommend that motorhome tyres should be replaced when they reach five years old and they certainly should not be used beyond seven years or you could risk a blow-out.
