1st time filling up Gaslow twin cylinders? (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
As the title say, about fill both cylinders for the first time.any particular things I have to watch out for/ take account of?:Smile:
David
Just follow the destructions and be aware that the level gauges are known to stick on first fill but will sort themselves out after a drive :thumb:
Link Removed
if you have an ASDA? usually under 65ppl
EDIT
A can of gas leak detection spray is handy to carry to check the joints after filling
A faulty hose not a loose nut
Link Removed
from the link above
11,578
25,390
South Wales
Coach built Adria
they recommend only a 3/4 fill first time to expel air from the cylinders and get the shut off level valves working.
when you disconnect after fitting dont be surprised by the escape of gas at the nozzle, its normal & i am sure you know bottle taps should be closed.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
refillable gas
Make sure both cylinders turned off. Take your time. There are normally instructions but if not, there will be someone in the garage who knows how to use it.
When on the road, if you see a garage showing 3 prices on the large sign on the road, chances are they have gas and that is the 3rd price listed. Usually BP garages have gas.
if you go abroad, I think there are 3 other fittings apart from the uk one.
in Spain, you may need toi check before hand, I think you can Google lpg spain and there is a map which shows where a lot of the stations are.
I'm sure its a decision that you will not regret :)
highwayman
968
1,029
Herne Bay
Low profile Rapido
Since 2005 ish
Once you've attached the filler you need to press and hold the button on the pump.
Or do as I did, stand there like a plum for a while and then refit the filler several times before realising I needed to press the button on the pump which was behind me :Doh: :Doh::Doh:
Cheers. Nige
Feb 24, 2013
13,072
101,433
Bolsover, Derbyshire
Hymer S800
not long enough
not got refillable gas on MH but have had LPG cars for years
All of above and I suggest a pair of rigger gloves, LPG is dangerously cold, the excess release when you disconnect can be significant and scary first few times
David
TheBig1
17,611
43,140
if you havent had the pipework pressure tested with air first, only put about 10litres in at first and check all joints with a leak tester spray. if all is sound fill up to about 30litres so you dont trigger the auto shutoff. it may not work on first use anyway and will free off as you drive
the above assumes you have 2x 11kg
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Be careful that you press and hold the correct button. I pressed what I thought was the right one in France once, and after not getting any gas for a while, the bloke came out of his kiosk and told me I was pressing the emergency cut out button.:Doh:
sedge
Jul 7, 2009
5,504
13,113
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Aha! - our Pilote fridge (Dometic) doesn't even attempt to light the gas for 15 minutes after you turn the engine off.
I cussed it quite a bit for not doing it, until I found out why. It's a jolly good safety feature, I thought.
icantremember
8,331
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Neither does our Thetford but I don't take it for granted ..... the time soon goes when you have problems like we did once when a non return valve stuck open so we had a huge gas cloud and a pool of lpg under the motorhome:Eeek:
Jun 30, 2011
7,231
20,083
Barnard Castle, UK
Concorde Concerto
I always switched off our 2 Alugas refillables when putting some in but the fitter at Autogas 2000 in Thirsk said it doesn't make the slightest of difference if you leave them open.
Paul.
Jun 10, 2011
464
361
Yorkshire (nr. Leeds)
Since 2011 (so a bit of a newbie)
I was thinking about getting this gas-lo thingy, or whatever they call it, but it all sounds worryingly complicated. I can just see me blowing up the motorhome.
I think I might just stick to good old Calor.
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
the best thing I ever done fitting the gas low system
never run out of gas now and a lot cheaper than calor rip off gas:thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
It's a doddle but not worth the investment unless you have gas heating. However the other advantage is not having to lug bottles around when changing empties.
TheBig1
17,611
43,140
it really isnt complicated and absolutely no more difficult or dangerous than swapping an empty calor for a full one.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Yorkyman.. Do NOT be afraid of fitting a re-fillable gas system.. Its just the same sized bottles, but they are filled at a petrol station that sells LPG.. You just put the nozzle in, give it a quarter of a turn to lock it to the fill point ( that you get fitted to the skirt of the van ) and then just press the button on the LPG pump and it will deliver gas to your system until the bottle reaches 80% full and it automatically cuts off.. Untwist the filler nozzle from the van and go and pay for it !!! You can't overfill the system..!!. You DONT have to lug heavy bottles around..!!! And when / if you change vans, you just swap it over to the new van.!! I have just removed my system from "the old van" and re-fitted it to my "new van".. It took an hour start to finish... One more word of advice,, Have a look at the firm "GAS-IT" they
are much cheaper than gaslow.. If payload is a problem, fit aluminium bottles from ALU-GAS.. Sorry to ramble on, but in my opinion its a no brainer !! PS. If you are a Europe traveller, then you need 3 little brass adapters that screw onto the filler point to adapt the filler point for the country you are in... Simples .....
Good luck. Mitch.. :thumb:
D
Dai Motorhome
151
19
Burnham on Sea, Somerset
a class
Well just back from operation Gaslow - no real problem after 10 mins trying to get the nozzle to 'mate' with the lugs- but practice will make perfect!! I shall make sure to find the cheapest in the area next time, as in my case the closest was probably the most expensive!!:Smile:
Thanks for all the advice - much appreciated!
Dai
TheBig1
17,611
43,140
http://www.filllpg.co.uk/
basic website showing best prices for lpg, but even better download and install their free app for your phone. shows locations of lpg garages near your location and the price. really simple but excellent:thumb:
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
As you are in the West Country, take a look at Countrywide Farmers. You can open an account with them at only 5% VAT and have access to all their filling points 24 hours a day. Cheapest I've found. :thumb:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Since you are in Burnham I suggest you get an account with Countrywide Farmers. They have depots at Bridgewater, Weston, Glastonbury and many more as you head up-country.
I have an account, paid by DD and they supply a 24/7 electronic key. I also benefit from paying 5% VAT on the LPG as it's for cooking and heating. You have to tell them that when setting up the account.
http://www.countrywidefarmers.co.uk...fuellingOutlets&pgForward=businesscontentfull
Sep 2, 2020
581
9,443
Ladybarn, Manchester, UK
Burstner Travel Van
Newbie
I was looking at prices last night 13kg propane bottle, 107.00 to buy and refill 52.00 didn't say if the 107 was for the bottle empty or full, but assuming empty thats 300+ for a two bottle set up, 2 x 11kg Gaslow about 650.00 and about 33.00 to fill, saving roughly 60.00 per fill, seems a bit of a no brainer to me refill aroud 5 time and its paid for itself.
