1st of many... (1 Viewer)
Uncle Bob
23
24
North Yorks
C class
Newbie
Okay, I'm about to finalise a deal on a 89 fiat swift kon-tiki 6 berth diesel with 85k on the clock... Nice looking van but do all these vehicles have rusty wings, inner wings, windscreen scuttles? This one is better than most but still has a bit on the inner....
The van is very clean but obviously 'lived in', a couple of soft spots in the flooring that apparently have been 'repaired' but apart from a few scuffs everything works, it starts on the button and although very slow chugs along merrily without a fuss. My 1st question would be is the £6.5k asking price about right? Is there anything I should be looking out for on these vehicles? Any advice is thankfully received :) cheers Bob
Feb 27, 2011
14,732
75,882
UK
Self Build
I think £6.5K is at the upper end of the right ball park.
But as with most things the value is in the eye of the beholder.
Not sure what you meant about soft spots but if it is what I think you mean I would get that checked out. If it is rot caused by damp you need to find out how far it goes before parting with any of your readies.
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Totally agree with gromett I'd get the floor checked first as could be a costly repair.
Uncle Bob
Uncle Bob
23
24
North Yorks
C class
Newbie
Ok.....
Right, what's the most likely cause of the soft floor? It doesn't feel or smell damp in the van and apparently it has been repaired before so could now be ok but it's left it with a couple of points (straight in from side door and in the centre of the mid dinette) that creaks and feels 'bouncy' underfoot.... Is it likely to have been a 'split' under the flooring or moisture ie. spillage/ door being left open that has been the cause? If the worst comes to the worst what will the cost be to replace? We quite like the van and I'm not shy at DIY as I do maintenance for a large hotel chain but I don't want to buy a 'pup' cheers for the heads up, Bob
TheBig1
17,630
43,262
with a van of that age, floor delamination is normal, but if it feels soft may well be water ingress. delamination is when the layers of ply and insulation seperate due to glue failing, fixing is relatively easy and cheap. damp or water ingress will need replacing and would cost more than the van is worth
kontiki vans of that vintage were given the name "leaky kontiki" for a good reason, they were highly prone to leaks
rust on such an old vehicle is inevitable but replacement parts like the windscreen frame and scuttle are very hard to source indeed.
as for value, I believe that £6500 would buy a van built in mid 90s, its worth more like £4500 - £5000 for a good one needing no work. Its a buyers market right now as theres more for sale than people buying. personally i would look at a newer van or at least one without well documented problems
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
The Talbot base vehicles rust away before your eyes. I would avoid at all costs.
If you've got possible damp in the hab section, I would be running away very fast.
