1995 boxer 350 LWB diesel cab heater (1 Viewer)
g4jnw
36
10
Anthorn, Wigton, Cumbria
Conversion
newbie
Im stumped a little, the cab heater is blowing on setting 4 only but cold not hot, i realise the resistor could be faulty as far as only working on 4 (setting 4 is bypassing the resistor) haven't managed to get hold of one yet - but thats not the problem - The van had a new heater matrix 30k miles ago. We have only had the van 2 weeks but just been on a 100 mile run and the heater is still cold, what else could i look at?
The temp gauge rises quite nicely to half way and hold the temp ok.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
I agree, probably and airlock in the matrix - the french engines have always been a pig to bleed - they can take ages!
Pop the cap and let it run, you can squeeze the pipes to help dislodge the air. You will see bubbles coming up from time to time - worse one I did took about two hours!:Doh:
G
g4jnw
36
10
Conversion
newbie
Thanks both of you will have a go at this over the weekend, recently bought it and it was sorn for about 5 months after returning from Spain but i see 30k miles ago there was a new heater matrix fitted so didn't think it would be that, hopefully its as simple as your advice :Doh:
Feb 16, 2013
19,725
51,979
uttoxeter
ambulance conversion
50 years
That will be it then, if they have had the pipes off to fit the new matrix, should be easy enough, if the squeezing don't do it you might have to take a heater pipe off and wait till it runs solid water , no air then put it back on while its still running out
Apr 9, 2013
663
373
Ayr
Newbie
As others have said, sounds like an airlock. Regarding your resistor, it may well be just a blown thermal fuse in the resistor pack. These can be replaced much more cheaply (a quid or two to buy on eBay or a lot less if you live near a Maplin/RS type shop.
Tim
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
could be the heater control valve has become disconnected,or has been disconnected as they sometimes leak,and some people put in rad weld or similar to cure the leak,but every time you change the control from hot to cold the leak would start again until the rad weld resealed,to get around this problem of it re-leaking some people disconnect the heater control valve leaving it in the cold position or the hot position.
long time since i fixed one but you will find the control valve on the side of the heater unit drivers side i think? cant remember 100% :Smile:
forgot to mention! some people bypass the heater matrix altogether after a leak inside the cab area,by joining both heater pipes together under the bonnet.
G
g4jnw
36
10
Conversion
newbie
Tim
Thanks Tim can you point me to the correct thermal fuse I live about 20 miles from a Maplin, there are quite a few and all different temperatures Link Removed
G
g4jnw
36
10
Conversion
newbie
DAM!!!!
Looked under the bonnet today after all our discussions, shows you shouldn't take all you are told by the seller as gospel!! - The heater matrix may have been fitted 30k ago but it looks at first sight like its been bypassed as the pipe that should go into it is joined with the other end, its a bit of a give away now i see it as where the join is the pipe comes over the top of the air intake pipe.
As they were living down in Spain they maybe thought they didn't need it, now am not sure whether to bother myself as we will be using it only though the summer, the easiest way maybe just to get a 12v cab heater but a bit disappointing it was only seeing one of the posts in this thread that made me look :Doh:
G
g4jnw
36
10
Conversion
newbie
Chris this is exactly what they did!!!! :cry:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
JJ taught me every thing i know about vans and fridges:thumb: :roflmto:
Apr 9, 2013
663
373
Ayr
Newbie
Ideally you should match the rating of the existing fuse. They seem to range from 160 to 230ish in most cars. If you go for 160 you'll probably be erring on the side of caution.
Note that you can't easily solder these in (you'll blow the fuse) and normally they are spot welded in. Auto electrical places may do this for you. Alternatively, if you cut the old fuse out leaving the full lengths of the old fuses legs behind, you can use the metal insides from a small chocolate block connector to connect the new fuse. (A connector like this http://www.flickr.com/photos/tudedude/3633464329/).
It's worth checking that there isn't a defect with the ventilation system that might have caused the fuse to blow in the first place. The most stressful thing for the fuse is low fan speed selection with perhaps blocked inlets or outlets leading to the fuse getting cooked.
HTH.
Tim
Apr 9, 2013
663
373
Ayr
Newbie
Bummer. :Sad: I wouldn't waste your time with a 12V heater. They're way too ineffectual to do anything useful.
As a purchaser of a 1997 motorhome I know all about finding hidden defects. Just keep telling yourself that it's all part of the fun! ;-)
G
g4jnw
36
10
Conversion
newbie
With a view now of not bothering with a 12v heater have taken the bottom section of the dash off, seems silly but I can't find the heater matrix or where it would have been had there been one fitted.
Searched the net to find out where it actually should be and all i can find is "just found my leaky heater matrix had to remove all the bottom of the interior dash then un bolt the gear stick unbolt the whole heater system disconnect the hoses from the engine bay and wiggle the whole unit out then take the matrix out .it s a pig still got to put it all back again"
either this guy has got a different year to me or im doing something wrong, mine is a 1995 2.5D NON AC model - the gear lever sits on the dash but i can see behind it once i remove the bottom section of the dash, can't see how to remove the gear lever as there is a rubber gaitor over it that is fixed to a square plastic section.
Looking through from the side i can't even see where the matrix would be - its starting to drive me mad :cry:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
the matrix is inside the heater box you have to remove the whole heater unit to access it:cry:
G
g4jnw
36
10
Conversion
newbie
ok, at least im not going mad, could do with a step by step guide to getting to it,
I see the heater box which is the big lump of plastic :thumb: thats as far as i go for now i guess.
At least if i can see the matrix i may be able to decide what to do.
So the instructions that i found on the net must have been for a later model then?
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
removing the heater box is a big job,i dont envy you one bit:cry:
might be an idea to buy a Haynes manual for you model,but i will look see if someone has information on the internet:thumb:
G
g4jnw
36
10
Conversion
newbie
Thanks Chris, looked for a manual and doesn't look like there is one available but no wonder they bypassed the matrix then
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
found this:thumb:
its a downloadable manual for a tenner,so get it today:thumb:
Link Removed
G
g4jnw
36
10
Conversion
newbie
Thanks for that will look at the website.
Have downloaded this manual 3 times and when i try to unpack it, even with different software, i get the same error, it says file either incomplete or corrupt, have emailed the company with no reply yet, the payment page worked though!!!
Jul 27, 2010
704
1,452
Farnham Surrey
Bilbos Nexa
on and off since 1980
As a purchaser of a 1997 motorhome I know all about finding hidden defects. Just keep telling yourself that it's all part of the fun! ;-)[/QUOTE]
As the purchaser of a 1999 motorhome, I know exactly what you mean!!
