1994 Hymer 654 Porch Light (1 Viewer)
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi everyone...
On my 654 there is a porch light above the door with a sensor, it is not working although the little orange switch on the far left hand side of the instrument panel when switched can hear an electrical "Fizz" like when a bad connection is made.
I cant seem to see how to get the cover off to see whats going on in there... I have seen a couple of plastic screw things on the inside of the door but they dont seem to do anything as they keep turning.
It would be nice to have that working, so could do with some advice on how to get off the cover etc to replace bulbs etc...
I drove it to work today so will take pics at lunchtime to show what I mean,...
Stu
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Ok got some pics of the porch light / switch and plastic screws at the back... they are upside down for some reason... any help would be fabulous"!
scotjimland
2,246
9,759
A Woosh bang
The orange rocker switch should just 'pop' out.. use a small screwdriver and gentle ease out.. there should be clips on the end of it that you can press in with the driver..
The light looks like the cover just clips on.. just try to ease it off with a small driver.. no excessive force.. if it' doesn't move don't force it.
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
hi stu i recently fitted a new bulb to the same porch light on my hymer and what you have to do is using both hands gently squeeze the long sides of the plastic lens inwards and ease the lens off [the little round white pir sensor stays behind] so you end up with a lens with a cut out for it. be very carefull with it because they do become very brittle with age and are very easily cracked . it might be worth running around the joint first with a blade just in case somebody has put sealer round it before you. regards garry
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Garry your a lifesaver... was trying to get the plastic screws undone with no luck lol,... will do that when i get home... will be nice to walk up to the van and a lil welcoming light come on... :)
Is yours powered via the orange switch?
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Which bulbs are they? ba15s? if so might wait as have some LED replacements coming for that sort....
greyman1
374
279
manchester
your very welcome, mine is operated from the main switch board above the hab door [1996 b534 lhd] it is wired via a switch marked battery aux . if i remember correctly it was a single contact 10w bulb . garry
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
fabulous... will wait till the other bulbs arrive... can test which switches control the power for the light then :)
The more I get fixed the happier i get :)
Thanks again buddy
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi all...
Got the cover off and replaced the bulbs but still does not work at night... will have to do some testing on the PIR i think...
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The plastic 'screws are probable nuts into which screws enter from the other side. The slot in them is just so they can be held if necessary whilst the screw is tightened.
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
since 1999
Hi all...
If your switch has 3 positions it's possible the centre position is OFF with the other positions permanently ON and ON via PIR.
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi Tony... its a single switch.. looks like the PIR has had some water ingress and is boned...
I will order a new one... found a replacement porch light exactly the same for less than £25 delivered..
Stu
PeterB534_1996
Southampton, UK
B534
Newbie
Hello All, just picked up a 1996 Hymer B534 - the outside light is not working, along with 2 internal spot lamps and the internal strip light at the back.
The circuit is attached to the Reserve button on the control panel. Looks to me someone has tried to modify the wiring in the past as the wiring to the rocker switch seems wrong (Maybe the spot lights are none standard parts thats the cause of the problem?)
Does anyone know what the Reserve button is supposed to do ?
Pete
