1992 Compass Drifter Floor
Discussion in 'Compass Motorhomes' started by jonandshell, Sep 10, 2012.
  1. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    Friends of ours have bought their first van, a 1992 Compass Drifter on a Ducato 1.9 TD chassis.
    The MH really is in good nick, but the floor puzzles me!:Confused:
    I haven't had time to examine the floor properly, but there is some springiness when I walk about on it. I have looked underneath whilst Shell has walked about and the ply floor springs under her weight, but only between the chassis members, as you might expect.
    Now, if the floor were delaminating, the flexing would only be felt underfoot and not visible when viewed from underneath.
    I suspect that the floor is only a single sheet of ply and not of a sandwich construction like more modern vans. The only insulation appears to be the carpet!:Eek!:
    Does anyone know if I am correct in this assumption? The body is completely dry and all seems well with the damp meter. I just haven't had the opportunity to check the thickness of the floor yet.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,681
    17,297
    YO11 2BD
    If the floor is only single skin ply and not a laminate then it would be at least 18mm (3/4inch) and shouldn't move under normal body weight.
    could be the ply is starting to rot :Sad:
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    Thanks, I was wondering, it seems my assumption about the floor construction was correct.:thumb:
    I get a chance to look at the van again on Wednesday, so I will get a chance to check the thickness.
    The floor appeared completely dry, but I wonder if the inter-sheet adhesive is degrading with age and causing the ply to loose its stiffness.:Sad:
    I reckon some reinforcement sheets glued and screwed from underneath could be the thing to help the van see out its days.
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Hi Chances are you are correct and it will have broken down over the years from road spray.The only answer would be to replace the floor but on such a van would not be worthwhile.Your "modified" solution sounds good but you may find you need a lot of extra screws as you will be screwing into basically delaminrated ply that is only 3/4 thick
    Terry
  5. ojibway
    ojibway Funster
    Jul 17, 2012
    530
    298
    Eastbourne
    If the ply is deteriorating I'd put a new layer of 12mm ply on top, not underneath as that would only be as strong as the screws you put in.
    12mm marine quality ply can easily be cut with an electric jigsaw and when you lay the carpet on top you won't even notice it. Secure it in place with No Nails or similar adhesive.
    You could use ply underneath but it'd be best to secure it in place with nuts and bolts and large washers. At the same time you could sandwich a sheet of polystyrene for extra insulation.
    Mike :Smile:
  6. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,533
    5,620
    Near Mold North Wales
    Jon is an expert on motorhome floors - I've witnessed him "flat out" on one!:Rofl1:
    • Like Like x 1
