1991 kon-tiki (1 Viewer)
saphire
Hailsham sx
Fiat ducato kon-tiki
Im a newbie
hi im a newbi at this my wife and i have just bought a fiat camper (1991 reg) with the idea that we will take eveyone on holiday next year:Cool: after ive repaired the engine :cry: but i cant seem to get any info about the camper and how/ where to switch things on and off or to drain the water :Doh:. Can anyone help me please would be very greatfull. many thanks saphire
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
I cant help with the information.
But welcome to fun
:welcome:
Mel & Lieve
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Hi and welcome to the site, nice of you to take us all on holiday, I fancy Greece and bags a window seat please.:thumb:
buckby
213
147
nottinghamshire
coachbuilt
The one I had had a leisure battery under the false bottom of the wardrobe and on the control panel there is a switch for the leisure battery or cab battery our fresh water tank was under the settee and there was a drain tap on it used to open the drain tap and open the taps on the sink and basin to drain down the cassette toilet had a drain on the fill tank outside hope this helps a bit
TheBig1
17,630
43,252
no 2 models are the exact same layout but the basics are
tank drain is normally at the end of a pipe leading from the bottom of the tank.
drain off for the boiler (very important as expensive) is close to the boiler lift yellow valve to drain
turn off water pump and open all taps
remove shower head and blow down pipe to exclude water
control panel will be a series of switches often near the wardrobe
engine and mechanicals look for a russek manual often found on ebay. theres been a few members on here rebuild these engines, somebody may even have a spare
oh and welcome to the site. i recomend spending the £10 on membership here to get the very best advice as you learn
Spenders
396
360
Tadcaster
Since Feb 2013
Hullo
Hi there Saphire,
Welcome to the site... as mentioned above you'd be well advised to pay the £10 subs then you can keep coming back to ask as many questions as you want/need. We've all been in your situation starting out, and trust me, the only silly question is the one you didn't ask!!
The checklist that The Big1 gave is pretty comprehensive in general terms and should see you right to start with. Get your name down for some of the rallies/meets and bring your van, there's always someone willing to help out and have a look at any issues.
Simon
:thumb:
barearse
90
71
van conversion
Just starting
Newbie
Welcome sapphire, as stated, once you post your van details on here then no end of first hand advice will be available from both past and present owners of same.:thumb:
