1990 kontiki questions
Discussion in 'Tech/Mech General' started by Tonymark, Aug 19, 2010.
  1. Tonymark
    Tonymark Read Only Funster
    Aug 19, 2010
    3
    Hi, I have recently taken the plunge and bought a 1990 Swift Kon-tiki on a Fiat Ducato 2.5 non turbo. As I try to familarise myself I have a few questions if anyone can help? 1. I want to fit new glow plugs but cannot figure how to remove the 4th plug ( Extreme left as looking at the engine). 2. There are 2 waste tanks, the one which discharges from the passengers side only seems to be piped to connect to the sink drainer. All other outlets to the rear tank, is this correct? 3. The gear stick has been welded at some point, it works fine and gear change is good, should I be concerned that it might break again? any spares out there? 4. Lastly I read that the rear axle need regular greasing. There appears to be grease around the nipples so that is promising!! However I am confused as to whether both sides have to be lifted together or if you can raise one and grease and then repeat on other side. While on this, is it acceptable to use a quality general grease as the recommended ones are proving difficult to obtain. Appreciate any advice there might be out there. TMark
  2. Mikemoss
    Mikemoss Read Only Funster
    Aug 14, 2007
    178
    49
    Corsham, Wilts
    Hello and welcome Tonymark. Can't help re glowplugs but someone who can is bound to be along in a moment. Re the AL-KO rear axle, I've read somewhere on here that it's fine to do the greasing one side at a time so long as the wheel is completed suspended off the ground.
    Pretty sure that any decent grease will be fine, too. It's something I ask our local MoT place to do for me each year and they only charge an extra £5er.
    Enjoy your new motorhome and here's hoping it gives you many miles of fun and pleasure.
  3. thehutchies
    thehutchies Funster
    Aug 31, 2007
    1,510
    1,631
    The Wheelèd Shed
    Hi Tonymark,
    I've always greased my Al-Ko axle one side at a time, with any old grease that comes to hand.
    For the other questions, you might ask here:
    Preloved Talbot Express
    The Fiat Ducato, Talbot Express, Citroen C25 and Peugeot J5 are all the same base vehicle and there are a lot of knowledgeable people on the above.
  4. barryd
    barryd Read Only Funster
    Feb 10, 2009
    1,144
    103
    Yorkshire Dales
    Just to throw a spanner in the works I had to have a new axle fitted on my Kontiki 640 this year as the old one was never greased and I didnt know. The cost was £2600. The general opinion through the several posts on the forums was that that both wheels need to be off the ground at the same time so there is no load. Im no expert but this was the general opinion. I dont think it just applies to Kontiki's but any Alko axle.
  5. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Agree am sure I have read this also, to release the tension to help grease penetration.
    Dave :thumb::thumb:
  6. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    load must be off the wheels....i have an alko kober hand book somewhere in the van which states both wheels off the ground at the same time.
    alko kober axle maintainance.
  8. thehutchies
    thehutchies Funster
    Aug 31, 2007
    1,510
    1,631
    The Wheelèd Shed
    I took a look at a cutaway diagram of an Al-Ko axle and decided that one unloaded
    wheel at a time was sufficient.
    No problems so far for me, but follow a counsel of perfection if you feel better. :Smile:
