14.4v Bulk Charge rate with AGM battery - Yes or No? (1 Viewer)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
The factory fit 24Kgs battery on our new MH is a Yuasa L35-100 100Ah (NCC Class C). Solar panel is 100W.
The Solar charger and the 3 stage (Sargent PX-300) 'intelligent' electronic charger's specifications both state the bulk charge rate to be 14.4v, and float charge rate as 13.6v.
I'm considering replacing the factory fit battery with a single battery of higher capacity, maximum weight 40Kgs, because we like to stay off EHU if we can, but don't use loads of electricity (ie no inverters, no air con).
The available online advice about whether or not to choose AGM batteries with the above charge rates is conflicting to put it mildy, even from the industry. I'm not considering Gel at present, however much anyone else might like them. I don't want to change my chargers.
So - any thoughts (based on personal experience/practical knowledge) on whether I should go for a bigger capacity NCC Class A Lead Acid, or its AGM equivalent? Thanks in advance.
funflair
19,305
30,071
Guisborough
MORELO palace
since 2012
If you can't run GEL just go straight lead acid and I would be tempted to go open serviceable ones.
Martin
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
AGM batteries differ in their charging requirements. That is why some chargers have AGM1 and AGM2 programs. Generally though, I understand that AGMs require a higher charging voltage and current than standard lead-acid or gel. Also, they charge much more quickly than gel so a gel program is unlikely to be suitable.
For example, Varta state that the charging voltage should be 14.8V for AGM and 14.4V for lead-acid. Also, they suggest a current of 10% of the nominal capacity for lead-acid and 25%-35% of the nominal capacity for AGM (see image). So, if you go for a total of 200Ah of battery(ies) say, that indicates a charger capable of 50 amps capacity, or more, and I doubt that your Sargent can manage that!
If it were me, I'd stick with good quality sealed lead-acid.
magicsurfbus
magicsurfbus
4,673
10,127
NW England
Since 1997
Detailed response much appreciated thank you @JeanLuc. As most of the NCC Class A batteries of higher capacity are AGM or Gel, and the MH's charging system only has a Lead Acid option I'm already inclining towards a Bosch L5 series 140Ah to see how we go. I can always flog the Yuasa on eBay to subsidise it.
I'd rather have a Class B with a 5 year warranty working properly than a class A being undercharged and packing up early.
However, I'm open to other suggestions on the subject if they're out there. Upgrading the chargers for more options is maybe for the future if things don't go to plan.
JeanLuc
3,304
2,199
Warwickshire
I switched to Varta sealed lead-acid a couple of years back and I'm happy with them. They have the same 'power grid' construction as the Bosch and make large sizes. I have 2 x LFD90 which are 90 Ah each, but they also make 140, 180 and 230 Ah sizes if you have room (and a small crane to lift them!).
https://www.varta-automotive.com/en-gb/products/varta-professional-dual-purpose
Lenny HB
53,315
149,512
On the coast in West Sussex
Hymer B678 DL
I would not risk AGM's with your charger you would be lucky if they lasted 2 years.For batteries I would go by Funsters recommendations, I certainly would trust the NCC list, not as unbiased as they make out.
